95 outside temperature probe troubleshooting procedure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2006, 07:46 AM   #1 (permalink)
Gameroom cash: $275055
I spend most of my time on the Camry forum. I am asking this for a friend who has a 95 Avalon. His outside temperature display is not working. I now know the sensor itself is located near the passenger side headlight, but I'm not sure how to troubleshoot this system. Does anybody know the procedure? Has anybody done this before?
Any help here would be greatly appreciated.
Mike
Old 06-29-2006, 07:39 PM   #2 (permalink)
View toyomoho's Photo Gallery
I can pull up a wiring diagram and perhaps diagnostic and sensor test info for the climate control system. Have you found the sensor and checked for damage, loose wires, etc? From what I can tell it is in front of the radiator. It is about the same height as the passenger headlight, but 3-4 inches toward the driver’s side.
What does the cars temperature display indicate when switched to outside air? Does the inside temperature sensor work? Any other symptoms beside the non-working sensor?
Old 07-01-2006, 11:31 AM   #3 (permalink)
"What does the cars temperature display indicate when switched to outside air? Does the inside temperature sensor work? Any other symptoms beside the non-working sensor?"
I'm not sure. I wasn't even aware there was an inside display too, as this is not my car and I am doing this from verbal information over the phone. I will try to find out and post back. Thanks for responding.
Mike
Old 07-05-2006, 04:13 PM   #4 (permalink)
I spoke to the owner of the car. It normally only displays the "outside temperature" on the display. Right now there is no reading there next to "outside temperature".
Does anybody know how to troubleshoot the system?
Mike
Old 07-07-2006, 09:22 AM   #5 (permalink)
View bentleyrb's Photo Gallery
My 95 Avalon 'outside temperature' has been blank also.
bentleyrb is offline   Reply With Quote
Old 07-08-2006, 03:05 AM   #6 (permalink)
Does this car(s) have a seperate temp readout indicator just for the outside air? Or does the indicator switch between inside and outside temp as part of the climate control system? Can you get anything to display on the indicator?
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 10:38 AM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 01:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 12:01 PM
