Light out Sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2006, 09:30 PM   #1 (permalink)
View mcbreaker's Photo Gallery
Light out Sensor
On my 98 avalon the burned out light sensor on the dash is still on despite checking that all lights are in working order is there any way to reset it? or should I just cut the wire?HAHAHA!
mcbreaker is offline   Reply With Quote
Old 07-10-2006, 10:53 PM   #2 (permalink)
View toyomoho's Photo Gallery
Sometimes a bulb socket gets corroded or the connection is bad. This causes a signal fault even though the bulbs are OK.
Old 07-11-2006, 07:10 PM   #3 (permalink)
TomC
View avalontom's Photo Gallery
What has worked for me is to change all the bulbs - tail, stop (including the middle one), blinker, & license plate lights. Then it's done for 4-5 years.
Tom
avalontom is offline   Reply With Quote
Old 07-20-2006, 12:14 AM   #4 (permalink)
View sickwilly's Photo Gallery
I am having this problem too on my 97. Found two of the brake lights burned out, replaced them, all seem to work, but the dreaded sensor light is still on. My next thought is to pull bulbs and do some sanding of the contacts, as well as keep replacing bulbs like Avalontom suggested.
Don't know why that light bothers me as much as it does, but I want it out.
1997 Avalon XLS (black, black leather, tinted windows), sold June 2009 with 183K on it, still looking and running great!
sickwilly is offline   Reply With Quote
Old 07-22-2006, 07:31 PM   #5 (permalink)
MDT Toyota Tech
View BadChicken's Photo Gallery
You can usually correct the problem by slightly bending the tangs on the sockets inward to make a tighter fit on the bulbs. The tangs become loose over time due to heat.
BadChicken is offline   Reply With Quote
Old 07-23-2006, 10:14 PM   #6 (permalink)
View carloi's Photo Gallery
Australia
did you replace your bulbs with LED types? Has anyone experienced the bulb out light when replacing the signal and brake lights with LEDs?
carloi is offline   Reply With Quote
Old 07-23-2006, 10:39 PM   #7 (permalink)
View Mayur's Photo Gallery
Try replacing bulbs and resetting ECU.
Mayur is offline   Reply With Quote
Old 12-20-2011, 03:57 PM   #8 (permalink)
View trickstar's Photo Gallery
What worked for me finally was to change out all four bulbs for fresh, new, matching bulbs from Walmart. Turned off the car, started it up again, that did the trick!!!
Jimmy
trickstar is offline   Reply With Quote
Map Lights Come ON with Dome Light (New Method) Pb 2nd Generation (2005+) 239 10-23-2011 11:28 PM
Help: OBDII P0130, P0133; MIL / check engine light towwang Hardcore Tech and Competition 7 11-03-2006 01:50 AM
piaa vs stock ProjectCorolla Archived Corolla threads 37 02-28-2006 07:08 AM
Bulb size? Ramenx 2nd Generation (2005+) 34 02-28-2006 01:11 AM
engine light on after replacing spark plugs CodyjCA Archived Corolla threads 17 02-11-2005 01:59 AM
