Water Pump - change with timing belt? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2006, 09:53 AM   #1 (permalink)
View tnltracy's Photo Gallery
Hi all. Can't seem to find specific info regarding changing of water pump/ thermostat with the timing belt. Is it necessary, or if not, convenient to do so on a 1997 Avalon? Does the timinng belt drive the water pump on this car?
Thanks for the input
tnltracy is offline   Reply With Quote
Old 07-25-2006, 11:52 AM   #2 (permalink)
X Avalon
View hsakuragi's Photo Gallery
yes, you should do both at the same time to save you money
hsakuragi is offline   Reply With Quote
Old 07-25-2006, 01:45 PM   #3 (permalink)
View toyomoho's Photo Gallery
Water pump bearings and seals tend to have a much higher failure rate after say 100K miles. Although pumps can go to 200K+ without a problem. The idea behind changing the pump at the same time is you need to take off the same parts to do either job. As such, changing out the water pump becomes just an extra ½ hour job, rather then a multi-hour job. As timing belt changes are recommended at 60K mile intervals, your opportunity to do this when changing the belt is limited.
If your car has over 100K miles, consider changing the water pump, idler and tension pulleys, and tension spring. At around 120K miles the idler and tension pulleys start to wear. If you really want to get into it, can change out the crank, oil pump and cam seals. Or at least inspect them for leaking when you do the job.
If you replace the water pump, the coolant system is drained and replacing the thermostat is now an easy job.
If you are doing the job yourself, shop around for parts on-line and at auto parts stores. The dealer also has the parts, but be prepared to spend more.
Timing belt change cost for Gen 3 V6? Keyser Soze 3rd & 4th Generation (1992–1996 & 1997–2001) 17 10-14-2006 10:44 PM
1990 LE - Timing Belt change - what else to change at the same time? Rubber Mounts? Gopal 1st & 2nd Generation (1983–1986 & 1987-1991) 2 06-28-2006 02:39 PM
when do u change the timing belt 2000AVALON 2nd Generation (2000-2004) 3 04-08-2005 03:33 PM
Mileage when timing belt change? Eniffey Camry & Solara Lounge 3 03-01-2003 02:09 AM
