1995 Avalon ABS Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2006, 08:25 PM   #1 (permalink)
2001 Camry LE
View Nuke209's Photo Gallery
we were fixing our axle this weekend and got it working, now the ABS light came on and I followed the guide on how to get the ABS error code, I got code 35 which is right front sensor I believe
So do i have to replace the sensor?
We believe it might be the wiring to the sensor, but it could be the sensor or both?
Can you guys help me please?
Nuke209 is offline   Reply With Quote
Old 08-01-2006, 01:37 AM   #2 (permalink)
View toyomoho's Photo Gallery
Code 35 I think is:
Open in left front or right rear wheel speed sensor circuit. Check speed sensor, sensor rotor, wiring harness and connector.
You might check all of the above for open circuits, loose wires, damage. Not sure how to test the speed sensor without an oscilloscope or special tool. It is a magnetic sensor. I suppose you could swap them out and see if the trouble code changes.
See link below:
http://www.advanceautoparts.com/engl...0030701as.html
Old 12-17-2006, 12:56 PM   #3 (permalink)
View nomadicflyer's Photo Gallery
Chasing a similiar problem here.... can the wires be spliced, or does the entire run need replaced? Anyone with experience on this?
Thanks!
nomadicflyer is offline   Reply With Quote
Old 12-17-2006, 10:39 PM   #4 (permalink)
You should be able to splice the wires OK, make sure you get a good connection.
Old 12-17-2006, 11:55 PM   #5 (permalink)
Thank you!
Old 12-19-2006, 09:11 PM   #6 (permalink)
View fj40supraman's Photo Gallery
First make sure wires aren't pulled out of sensor. If they are replacement is eminent as they are molded in the housing. Suspension work does this a lot of times.
Current- '97 Avalon w/ 100k
'99 Avalon w/ 200k, sold to friend (1MZ-FE)
'86 4-Runner- wrecked and sold (22R-E)
'85 Corolla- engine lost compression=junkyard (4AC)
(3S-GTE MR2 or 2JZ-GTE Supra as soon as eng. degree pays off)
fj40supraman is offline   Reply With Quote
1995 Avalon - Ignition Clicking Noise Avalon95 1st Generation (1995-1999) 2 07-06-2006 08:18 PM
engine/ABS light help.... trninhds Camry & Solara Lounge 11 06-18-2006 12:06 AM
ABS problem?? n33k Camry & Solara Lounge 1 07-06-2005 10:17 AM
vacuum sucks! 1995 4afe problem madalo Archived Corolla threads 4 02-08-2004 02:49 AM
