1997 Temperature Gauge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-03-2006, 02:36 PM   #1 (permalink)
View bill50's Photo Gallery
Gauge always goes to center and does not deviate. Any help to see if the gauge is accurate.
bill50 is offline   Reply With Quote
Old 08-03-2006, 05:43 PM   #2 (permalink)
View toyomoho's Photo Gallery
Some cooling systems can regulate coolant temperature remarkable well. On my Toyota, once the engine is warmed up, the temp gauge stays put regardless of driving conditions or outside air temp.
The coolant system has more then one sensor. If the coolant temp was too far out of specifications, the ECU might pick it up, then respond with a “check engine light.”
If you want to get into it, you will need an ohmmeter and test data for the gauge coolant sensor. Or you can just change the sensor. You can test the indicator gauge by grounding the coolant sensor wire, then seeing if the meter moves all the way into the “red.” Keep this test short! Otherwise you might damage the gauge.
The other thing to check for is the coolant fan(s) kicking in and out. If they are not on all the time, but cycle in stop and go traffic or times prolong idle, then the coolant system is most likely OK.
Old 08-03-2006, 06:22 PM   #3 (permalink)
View sloopercat's Photo Gallery
Find somebody with an IR heat sensing gun. Almost any decent shop will have them. If not they can be bought for $60.
sloopercat is offline   Reply With Quote
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 11:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 01:49 PM
temperature gauge, 1997 Avalon bill50 1st Generation (1995-1999) 0 07-19-2005 11:03 AM
