How to remove headlight lens - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2006, 11:59 AM   #1 (permalink)
PB65stang's Avatar
View PB65stang's Photo Gallery
Can anyone tell me how to remove the clear headlight cover on a '95 Avalon? My headlights have some hazing, and I was wanting to clean them up, but can't seem to get the covers off. At first glance, I thought it was just the three clips at the top, but the cover wouldn't budge after removing them. Any tips/ideas? Thanks.
2009 Toyota Tacoma - Double Cab Sport 4x4
1965 Ford Mustang Coupe - 289 V8, auto. The summer toy/weekend warrior.
PB65stang is offline   Reply With Quote
Old 08-12-2006, 10:02 PM   #2 (permalink)
Frankie Avalon
KeepItSimple's Avatar
View KeepItSimple's Photo Gallery
Yes I'd also like to know because my '95 lenses looking pretty hazy too. I saw those clips but just knew there had to more to it that!
BTW does anyone know if that haze comes off or is it permanent?
KeepItSimple is offline   Reply With Quote
Old 08-12-2006, 10:47 PM   #3 (permalink)
View NYLexSC's Photo Gallery
The lens itself will not come off. You will have to remove the whole headlight housing itself. To remove the lens, usually you need to heat up the area around the lens to loosen the glue/sealent and then pry it open. It's a lot of work to open up a pair of headlights. To clear up the hazing (which is going to be on the outside only most likely) use a plastic polish like 3M Platic Polish or Meguiar's PlastX and apply and buff it off. If you're doing it by hand, it will take several applications and a good amount of elbow grease. With an electric buffer, results will be like new.
NYLexSC is offline   Reply With Quote
Old 08-12-2006, 11:15 PM   #4 (permalink)
519
Custom User Title
519's Avatar
View 519's Photo Gallery
Start on the underside. use a heatgun to soften the the seals and wedge a screwdriver into a corner carefully. Next, work the heatgun back and forth on the underside until the seal is softened, be careful not to melt the plastic though. while doing this, use the screwdriver to pry the housing apart.
do this on all sides and you'll get it apart.
'99 Corolla VE
*If you're having car problems, I feel bad for you son...*
*I got 99 Problems but my toy ain't one.*
519 is offline   Reply With Quote
Old 08-13-2006, 02:18 PM   #5 (permalink)
View sloopercat's Photo Gallery
Polish in place, I doubt the inside is cloudy. You will make a much bigger mess trying to take them apart.
sloopercat is offline   Reply With Quote
Old 08-13-2006, 06:52 PM   #6 (permalink)
PB65stang's Avatar
Awesome, thanks for the replies.
Old 08-13-2006, 06:57 PM   #7 (permalink)
silverxls's Avatar
View silverxls's Photo Gallery
found this link in the detailing forum...has good info i think...
http://www.contour.org/ubbthreads/sh...&Number=571871
silverxls is offline   Reply With Quote
Old 08-13-2006, 11:04 PM   #8 (permalink)
View fj40supraman's Photo Gallery
There is a great post on this at www.mkiv.com in the FAQ section. You will have to search for a bit to find it. I got new lights and covered them with paint protection film, this however willn't keep the polycarbonate from yellowing thou as that is UV breakdown. Good Luck!
Current- '97 Avalon w/ 100k
'99 Avalon w/ 200k, sold to friend (1MZ-FE)
'86 4-Runner- wrecked and sold (22R-E)
'85 Corolla- engine lost compression=junkyard (4AC)
(3S-GTE MR2 or 2JZ-GTE Supra as soon as eng. degree pays off)
fj40supraman is offline   Reply With Quote
How to remove a headlight Gen 3 YESCA 3rd & 4th Generation (1992–1996 & 1997–2001) 26 04-29-2010 07:51 AM
dashboard & front seats Midnight87 Supra Forum 6 07-09-2006 06:09 PM
How Remove 98-02 Front Turn Lamp Lens? petec Archived Corolla threads 2 10-15-2005 02:12 PM
Final product -- clear headlight lens and lighting pics (56k go take a dump) Tony the Tiger Camry & Solara Lounge 22 03-02-2004 10:17 PM
