Originally Posted by toyomoho
P1410 seems to be EGR position sensor circuit malfunction. Open or short in EGR valve position sensor circuit, EGR valve position sensor or ECU.
I just changed my egr pos sensor last week. I have a post on this which I will paste here.
I recently changed my EGR Pos sens. I should know in a few days after 3 drive cycles or so if I fixed it. I also got the infamous p1410 & 1411. I tested the sensor. Be very careful. Just because it reads normal resistance at 1st doesnt mean its good. When I had the ohm meter on it, the resistance had a very small but noticable open or dead spot when I pushed the plunger in and out. If you do it too quickly, you may miss it and inadvertantly put a bad sensor back in. I ordered mine from toyautoparts.com for less than 55 bucks with shipping. easy to change removing 3 7mm nuts. Watch out, there is a o-ring gasket seal which you can reuse as long as it didnt rip open. I will keep you informed if it works out or not.
Thanks,
Steve
csaxon
Great!, I wish more people would learn to use a DVOM to analyze their problems.
Yes I did indeed use a DVOM. But, it would be better in this case believe it or not to use an analog VOM. This way, you can actually see the meter physically go up and down. It should go up & down smoothly as you slowly push the plunger in and out slowly. BTW, I was wrong. I thought I bought the sensor from toyautoparts.com . I bought another part I needed from them there. I got the sensor from a user on ebay. Sorry for the confusion. Also I haven't had a chance yet to give the car a few more drive cycles to see if I fixed the problem yet. I'm still recovering from major kidney surgery.
Thanks,
Steve
So far so good. I put the comp on it. All tests completed. No codes. Keep fingers crossed. I think I fixed it.
Steve
I hope this helps you.
