Hello, i'm not sure if anyone can help me on this since i have not been able to find ANYTHING on the web that has helped me yet but here goes:
I am helping a friend of mine with installing a after market head unit and subs in his 1995 avalon. after buying a wiring harness (1989-2001 toyota..package even says 1995 avalon) and removing the dash and factory head unit, we find that in no way will this harness work. so we search the web and cannot find a single wiring harness that looks like it would connect to his factory harness. as far as i know he has only the factory cassette player/am/fm radio, no factory amp.
so we decided to hard wire to the factory wiring. once again we searched the web for any type of wiring diagram/information as to what wires go where... all we found was wiring for the factory amp...light green, pink, light blue, and other colors that in no way match the factory wires in his car (blues, whites, a red, blacks, greens, yellow, black with red stripe, and can't remember others off top of my head...14/15 total) . If anyone could give me any information that differs from what i've found already, it would greatly help. Thanks.
That harness will not work because there is no harness for that year Avalon. Since all stereos offered in the Avalon used an external amplifier, Toyota did not include the set of wires that the harness would plug into. To do a proper job, you will have to remove the glovebox and splice into the wires on the output side of the factory amp. I would not recommend using the factory wires that run from the head unit to the amp since they are of a very high gauge and cannot carry much current.
Just an FYI, the factory amp is a 42.5 watt/channel (170 total) jobber, which is less than most aftermarket headunits. I believe the plugs are blue and green, but its been 3 years since I did the job on my Mom's Avalon so I may be wrong on the colors.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
I just did my 95 and the info that sickwilly provided made it easy. The only problem I ran into was getting the power antenna to work. After looking at the wiring diagram in the haynes manual I realized there are two wires that have to be connected to the head units antenna wire.
I'm not talking about the antenna signal coaxial cable, I'm saying that I had to connect the blue wire from the radio to two other wires to get the power antenna to go up and down.
So you would just unplug the blue and green connectors that go to and from the amp, cut those connectors off and splice by color to bypass the factory amplifier?
Going from blue and green bypassing the factory amp, can anyone PLEASE tell me which of these wires provide constant for memory? I'm so stuck with this.
AM reception is usually affected by the quality of the ground of the antenna mount. Check the ground if you are having poor reception. Could be the paint where the antenna is mounted is preventing a good ground.
what you need is simple - a power wire and a ground. it would be nice to find a wire that goes hot when the dash lights come on, a wire that triggers the power antenna and some speaker wires...
you can run wires to the speakers. the amps are hidden behind the glove box, next to the ecm. you can cut the plug and use your hand to identify the wires to the amps (touching them will produce a hum in the associated speaker)
likewise, touching a hot wire to the wire that raises the power antenna will identify it...
Ok, couldn't find the constant going from the green or blue connector so I tapped into the courtesy light's positive. Problem solved, Pioneer AVIC installed!
