cruise control light flashing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2006, 05:23 PM   #1 (permalink)
View timber_cruiser's Photo Gallery
Hello, I am a new user to this forum and would like to get some advice on fixing my cruise control. I have a 1996 Avalon, a great car with 134,000 miles. Recently the cruise control start to flash and will not work. I would like to try and fix this myself if I could get my hands on the problem and find out more about what needs to be replaced or fixed. Any advice or suggestions would be appreciated!
thnx!
timber_cruiser is offline   Reply With Quote
Old 11-26-2006, 11:04 PM   #2 (permalink)
View toyomoho's Photo Gallery
The flashing cruise control light means the system is not working. A trouble code has been stored in the computer. Suggest you get the code(s) read; they are very specific to the problem area. Try Autozone, they may do it for free or will loan you the reader.
Old 11-27-2006, 02:36 PM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
Look for the cruise control actuator next to the battery behind the radiator. The actuator is concealed beneath a cover at the other end of the cable connected to the throttle body.
Look for a loose or disconnected connector on the front of the cruise control actuator. Might just be the electrical connector on the cruise control is loose. See if taking the connector off and pushing it back on solves the problem.
One other option is the brake light switch. Pressing the brake disengages the cruise control. The switch may be loose and need adjusting or may be worn out and needs replacing. If out of adjustment it may short out periodically
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 11-27-2006, 03:02 PM   #4 (permalink)
Check the plug in the middle of this picture.
Old 02-24-2007, 09:50 AM   #5 (permalink)
View TMack409's Photo Gallery
My 1996 has same symptom. But it's intermittent. I find that I can recover from 'Flashing" by pulling the cruise control lever toward me - (this is the "de-activate" position). It can take several times of first activating the system and then pulling back on the lever to clear the system. Sometimes only shutting down the engine will cure it.
The problem seems to arise when using the brake pedal to de-activate the cruise control. When I then turn the system back on and try to set it - then the flashing begins.
I think I'll try cleaning the connectors as has been suggested (Using DeoxIT from Radio Shack). I'll post back with results.
TMack409 is offline   Reply With Quote
Old 02-24-2007, 03:18 PM   #6 (permalink)
If you have a trouble code. Might download the service info for the Gen_4 Carmy at the link below. The Camry and Avalon are almost the same car and may have the same system.
http://oregonstate.edu/~tongt/camry
Old 02-24-2007, 03:30 PM   #7 (permalink)
Thanks for the headsup! I skimmed that area earlier and felt like I would probably have to invest in a code reader first.... ;-) If I buy any more electronic stuff for my cars...she's going to divorce me. Heh, the portable 4-gas analyzer I bought last year nearly did it ;-)
As I mentioned, if I tinker with it, I can get it working....
Old 02-24-2007, 05:39 PM   #8 (permalink)
You can read the cruise control codes without a reader using the dash light. Also AutoZone will read codes for free.
Old 02-25-2007, 07:45 AM   #9 (permalink)
Thanks again, Toyomoho. I pushed forward, and read the codes by flashes. I seem to have more than one stored...... Anywhooo, I did not feel like taking the steering wheel apart (because the control switch was indicated in the error codes) so I dribbled DeoxIT down on it and wiggled the switch in all directions. For grins, I also cleaned the contacts on the electrical connector in the actuator (with Deoxit). It works fine now. I'll keep you posted and thanks again.
Intresting cruise control problem metalo69 Camry & Solara Lounge 3 05-26-2006 11:01 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
Cruise control problem burchard Camry & Solara Lounge 7 08-17-2004 08:58 PM
Cruise Control Problems on Echo HB EchoHatchLe Yaris, Vitz and Echo Forum 0 05-30-2004 01:43 PM
cruise control light blinking t100 weel T-100 3 09-18-2003 09:09 PM
