Hi guys i have a question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-16-2006, 11:16 AM   #1 (permalink)
View 99avalonz's Photo Gallery
Hello i am new here and i have a question about my dad's 99 avalon. For some odd reason when it rains there is water in his trunk area especially where the spare tire is placed.. the water does not drain out also unless we take it out it just sits there. Anyone know the reason why this happens or where the leak is because we have tried looking for leaks but cant seem to find it. Thanks alot!!
99avalonz is offline   Reply With Quote
Old 12-16-2006, 12:12 PM   #2 (permalink)
Official Member
steve326a's Avatar
View steve326a's Photo Gallery
Gen1
Hello there. Welcome to TN. Glad your here. As for the leak in the trunk, Toyota has a service bulletin on it I believe. I will go through my bulletins to see if I have it. If I do, send me your email in a private message and I will send it to you.
Thanks,
Steve
** 97 XLS With All The Toys! My Baby! **
** Enjoy & Long Live Your Avalon! **
FOR SALE MOVING! $3400 OR BRO
steve326a is offline   Reply With Quote
Old 12-16-2006, 09:29 PM   #3 (permalink)
Ok Thank You!!!
Old 12-16-2006, 10:18 PM   #4 (permalink)
Official Member
steve326a's Avatar
Gen1
Ok Thank You!!!
I am truly sorry. The service bulletin covers trunk leaks for different vehicles including a 01 avy. 99 isn't mentioned. And since 01 is Gen 2 and 99 is Gen 1 they aren't similar enough to use. Again I'm sorry.
Thanks,
Steve
Old 12-17-2006, 09:28 AM   #5 (permalink)
View joeking's Photo Gallery
Take your garden hose out and see where it is leaking. Just guessing but I would say it would be a weatherstripping leak. Go get some weatherstipping glue and see if you can fix it. The glue dries very quickly and works well. Good luck.
joeking is offline   Reply With Quote
Old 12-17-2006, 11:41 AM   #6 (permalink)
Official Member
steve326a's Avatar
Gen1 RE: 99 Trunk Leak
I scanned the whole avalon forum for trunk leak and got several entries. The one that seems to match your situation is this link:
http://www.toyotanation.com/forum/t47488.html
I hope it leads to a solution.
Thanks,
Steve
Old 12-17-2006, 09:45 PM   #7 (permalink)
View toyomoho's Photo Gallery
Check the link below for same problem on a Carmy.
http://www.toyotanation.com/forum/t136680.html
Old 12-18-2006, 09:56 AM   #8 (permalink)
View sickwilly's Photo Gallery
mine leaked. There is a twisty tie holding the wiring harness for the rear lights on the left side arm that hold the trunk lid. It came loose and grabbed the weather stripping/rubber boot on the upper left hand side of the trunk space. I reattached the wiring harness, straightened out the rubber boot, and have not leaked since.
Check it out on yours.
1997 Avalon XLS (black, black leather, tinted windows), sold June 2009 with 183K on it, still looking and running great!
sickwilly is offline   Reply With Quote
Old 12-19-2006, 10:04 AM   #9 (permalink)
thanks alot of the info guys i will check it out and see whats happens
Old 12-19-2006, 08:31 PM   #10 (permalink)
View sloopercat's Photo Gallery
You also might try pulling the trunk seal off and rotating it 180 degrees from where it sits, the rear vertical surface gets a lot of wear. I finally cured the leak by replacing that seal. My left side well also filled up, I ended up caulking around that vent in that well, both in and out to stop that leak, there is no good way to remove that vent/flap piece and replace the seal around that vent.
sloopercat is offline   Reply With Quote
50 Things women should know about us guys.... 95WhiteCamry Off Topic 33 06-03-2006 10:41 PM
Guys, have you ever gotten your girl to do the "Dirty Deed"? SmokingTires Off Topic 70 06-15-2004 07:16 PM
The Guys Rules!! #1 (attn: Girls) TRDragoon Off Topic 28 04-07-2004 03:23 PM
Question for guys with CAI's crazy_camry Camry & Solara Lounge 17 02-05-2003 02:33 AM
