o2 wiring problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2007, 12:26 AM   #1 (permalink)
Just Wanna Drift
NIXmx's Avatar
View NIXmx's Photo Gallery
Exclamation o2 wiring problem
Ok, so heres the story. I swapped the engine (replacement) on my 95 XLS and I ripped the o2 sensor out from the connector. It's the o2 under the car. I would like help finding out which wire goes into which hole. Its in contact, but I don't know which is which. The cooradnating wires are different colors so I can't match them up that way. The connector has a number on it. I'm not shure if it would help. The number is 11027 .Thanks.
NIXmx is offline   Reply With Quote
Old 01-15-2007, 03:14 AM   #2 (permalink)
View toyomoho's Photo Gallery
Does not the color of the wires carry over onto the other plug?
Old 01-15-2007, 12:11 PM   #3 (permalink)
Just Wanna Drift
NIXmx's Avatar
No, that was my first hope.
Old 01-15-2007, 12:40 PM   #4 (permalink)
View toyotacamry34's Photo Gallery
I would bring in your O2 sensor to your local Toyota parts department, explain the situation and ask to see a new O2 sensor. Compare the new vs old and you should be good to go.
toyotacamry34 is offline   Reply With Quote
Old 01-15-2007, 07:33 PM   #5 (permalink)
Just what colors do you have?
The 02-A/F sensor incorporates the sensor and a heater. Two wires go to the heater, two go to the sensor. The heater portion receives 9-14v with igntion on. The sensor portion receives a pulsed signal.
strange 92 5s-fe wiring problem, help please! chris86gts MR2 Forum 1 03-22-2006 09:24 AM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
Blacktop O2 Sensor Wiring MississaugaGTS Archived Corolla threads 3 08-17-2005 05:37 PM
Speaker wiring problem. HELP! iamquand Audio, Video, and Security - Tech 11 08-13-2004 11:23 PM
