Having an alarm problem with a '97 XLS
I own a fully loaded '97 XLS. I recently installed a Bulldog remote starter with my brother. Wiring should all be correct.
The problem is that sometimes the car feels like starting and other times it won't. Sometimes it works just fine, but then the other times, the horn starts blaring until I put the key in the door. I deduced that either the remote was programmed incorrectly. I reprogrammed it to no avail. Then I noticed the security light. So I was wondering if this is the problem.
Is there a security system in the '97 XLS (it's fully loaded, so I'd assume so)? If so, is that what's constricting the Bulldog system to work correctly? Where is the stock alarm so I can possibly disable it?
Thanks!
'97 Toyota Avalon XLS
- Pioneer Premier DEH-P980BT
- Bulldog Security 200B remote start
