sUSPENSION/STRUTS/SHOCKS PROBLEMS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-12-2007, 10:45 AM   #1 (permalink)
View Jagalag's Photo Gallery
Gen1 sUSPENSION/STRUTS/SHOCKS PROBLEMS
i'VE HEARD FROM cONSUMER REPORTS THAT the Gen 1's are notorious for problems with their suspension systems, is this trus and what should one look for if that's happening??
Jagalag is offline   Reply With Quote
Old 02-13-2007, 12:59 AM   #2 (permalink)
View toyomoho's Photo Gallery
The V6 Camry and Avalon is almost the same car. Might check the Camry Gen_3-4 posts.
I don’t think the problems were major. The suspension has a few problems with noisy front and rear suspension bushings; upper shock mounts wear out, stabilizer bar bushings. Toyota has TSB’s on many of these issues.
Old 03-03-2007, 12:13 PM   #3 (permalink)
View RStocker1's Photo Gallery
USA
Originally Posted by toyomoho
...Toyota has TSB’s on many of these issues.
Sorry if this question has an obvious answer, but where could I find these TSB's? I'm having a vibration problem at speed, and the guy who balanced my tires said I have a bad "strut tower". The book doesn't show a "strut tower"...it has Suspension Support, Bearing, Spring Upper Seat, Upper Insulator, and Spring Bumper (any of which he could have been talking about).
_____________________________________________
1998 Avalon XLS (White, Quartz Cloth)
RStocker1 is offline   Reply With Quote
Old 03-03-2007, 01:08 PM   #4 (permalink)
smuook's Avatar
View smuook's Photo Gallery
Let me know if this is what you are looking for:
http://www.avalonfaq.com/files/frontsuspensionnoise.pdf
smuook is offline   Reply With Quote
Old 03-03-2007, 01:12 PM   #5 (permalink)
smuook's Avatar
This one might help also:
http://www.avalonfaq.com/files/steeringnoise.pdf
Old 03-03-2007, 03:17 PM   #6 (permalink)
USA
Looks like it might be it. Have you (or anyone else) ever replaced those, or should it be done at a dealership (my '98 is LONG out of warranty). And did it help the problem?
Old 03-04-2007, 09:12 PM   #7 (permalink)
blh
View blh's Photo Gallery
I recently sold a 95 that I purchased new. It had 120,000 plus on it and I never had any front end problems except replacing the rack and pinion because of a leak. It was the most trouble free car I have ever owened.
blh is offline   Reply With Quote
Old 03-06-2007, 07:23 AM   #8 (permalink)
luvlegs
View luvlegs's Photo Gallery
We had a problem like that - if you hit a pothole, you thought you had just torn out the front wheel!
In 2000, the dealer replaced one strut on our '99 (at about 23k) - AFTER first sending the wife home with it telling her "the bolts were loose" - a pebble in the road sounded like the frame was hitting the ground. I took it back and told them "uh-uh" something is wrong with the strut - they just replaced it and that was that (no arguement or anything). It made a huge difference. When we hit 90k, I got a good deal on a new set so I did them both - it was like the original was "bottoming out"... after that, it was like riding on cloud 9 - nice and smooth... easy enough to do with at home too (I think after that, I had the alingment checked........I hope I did...........
luvlegs is offline   Reply With Quote
Old 03-06-2007, 04:08 PM   #9 (permalink)
TomC
View avalontom's Photo Gallery
Jagalog,
Yeah, I used factory parts & replaced all 4 struts and mounts. Ride didn't change much, but handling was back to normal and all the weird front end noises disappeared. You need a spring compressor (Harbor Frt has a cheap one) and a good tool set. It's not a job for the faint of heart.
Others can comment on KYB and other brands; I just wanted the security of having parts that fit.
Good luck!
Tom
avalontom is offline   Reply With Quote
Old 03-06-2007, 06:15 PM   #10 (permalink)
USA
Originally Posted by avalontom
...It's not a job for the faint of heart.
Yeah, I've only got about 36k on mine, and I was wondering about just replacing the old mounts with the new ones from the TSB.
Known problems slcpunk General Lexus Discussion 3 12-16-2005 11:51 AM
Electrical Problems - Searched and found little help. Delay_FTB General Discussion 5 12-05-2005 03:43 PM
electrical problems arising... battlekat49 Camry & Solara Lounge 2 08-14-2005 01:40 AM
1999 Camry problems nonstop only 28,800mi neuspeed 3rd & 4th Generation (1992–1996 & 1997–2001) 3 05-04-2004 12:03 AM
