Avalon door filling up with water! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-02-2003, 04:58 AM   #1 (permalink)
Zee
View Zee's Photo Gallery
"honey, what is that splashing sound behind me?"
No fooling, the driver's side read doo was half filled with water during the recent strecth of rainy days (18 of 23days).
It seems like some piece of trim is blocking a drain hole. Took nearly an hour to let it all drain oout.
Anyone heard of this?
"Can't understand why people abort Volvos, either"
'03 Toyota Avalon, 40,000 '96 Toyota Avalon, 126,000 miles
'89 Volvo 740tic, 120,000 miles '86 Volvo 240DL, 220,000 miles
'95 Ford Contour, 125,000 miles '88 Ford Escort GT, SCCA ITB
Zee is offline   Reply With Quote
Old 07-02-2003, 05:03 AM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
ouch, heard of floor drains not working,
never heard of a door though, that must be some damn good sealing in an avalon door...
oh well, it happens
-Nick
Nick is offline   Reply With Quote
Old 08-08-2003, 01:31 PM   #3 (permalink)
TN's ExercisePhysiologist
Bunthy's Avatar
View Bunthy's Photo Gallery
Talking I'm not the only one with window water!
Zee, I feel you man!! I was at sixflags NJ that weekend, when my friend told me that I got water in the wondow. I thought, yeah right your funny, but when he swung the door in and out.....water.....
solution: I drilled two holes on the bottom of the door. Its only a temporary thing for now, but heck it helps to minimize the splashing sound.....
You'll like being blown
Bunthy is offline   Reply With Quote
Old 08-08-2003, 04:08 PM   #4 (permalink)
Arimport.com GO there
95XleV6's Avatar
View 95XleV6's Photo Gallery
have you check all of the seals?
[img]C:\Documents and Settings\Chris Hoing\My Documents\My Pictures[/img]
95XleV6 is offline   Reply With Quote
Old 08-08-2003, 09:59 PM   #5 (permalink)
View lonis's Photo Gallery
i have an avalon and i have a problem with the trunk filling up with water, so i pulled the plugs in the wheel well. its a pain in the ass, ive even gone as far as getting in the trunk closing it and having a friend hose the car down and see where it was leaking, with a flashlight, unfortunately no success yet...
Lonis
1998 Toyota Avalon XLS and yes... the 'S' stand for Supercharged
1/4 mile - 14.5
lonis is offline   Reply With Quote
Old 08-09-2003, 08:46 AM   #6 (permalink)
View tavalon's Photo Gallery
i have the same problem. try checking the seals in the trunk. it may look like its seal, but its actually not. also check the hole in the middle of your spare tire
tavalon is offline   Reply With Quote
Old 08-09-2003, 11:05 AM   #7 (permalink)
Bunthy's Avatar
for the windows...
I've checked around and there doesn't seem to be any holes, or leaks along the window trim, glass or door. Its weird how water just gets into the door. I think that maybe..just maybe it could be the little 3mm gap between the trim above the door handle. I know it sounds off, but I looked at all the other trim on the other doors, and there shut tight. So go figure.
Old 08-09-2003, 06:55 PM   #8 (permalink)
Official Acura Troll
View 02RSX90camry's Photo Gallery
yo, what year are y'alls avalons? my dad has an 00, and we haven't noticed this yet. That's pretty freaky. for all y'all that havne't drilled holes and crap, have u tried taking it to the dealer and seeing what's up?
lol, just noticed i've used the work y'all in all my posts thus far
02RSX90camry is offline   Reply With Quote
Old 08-10-2003, 12:09 PM   #9 (permalink)
Bunthy's Avatar
I have a 96 avalon. i got it from a private party so I dunno if I can take it to yhe dealer. I think its only occuring in the 95-97 years. But still I think drilling it is a temporary solution til I find the leak...
Old 11-06-2004, 10:10 AM   #10 (permalink)
View craneman's Photo Gallery
I just had the same thing happen to me. I found some square holes along the bottom of the door and tryed to poke A wire up there no luck. Then I found two small plastic plugs at each end of the door and pulled them out. It was like A water fall.
craneman is offline   Reply With Quote
Old 01-25-2005, 08:38 PM   #11 (permalink)
View dmem1's Photo Gallery
I have a 97 Toyota Avalon with the same problem with water filling up in the passenger side rear door. Has anyone found a solution to this problem?? Please help!
Thanks
D
dmem1 is offline   Reply With Quote
Old 01-31-2005, 12:30 PM   #12 (permalink)
toyo man for life
View 97avalonxls's Photo Gallery
i found the lowest place on the door that was outside, but would drain onto the exterior footwell. I drilled a small, 3/16 hole there and after the initial waterfall, I have not had any water accumulation issues since.
ps I also sealed the door, out side of interior metal a,dn inside of interior metal, to keep any water that is travelling through the door out of the cabin. two years, still not a problem
Peace cannot be kept by force, it can only be achieved through understaning. - Al Einstein
97avalonxls is offline   Reply With Quote
Old 11-05-2007, 05:07 PM   #13 (permalink)
View abfhand's Photo Gallery
I have a 98 avalon and the driver side rear door was filling with water. I rolled down the back glass about 6'' and you could move the glass around. must be getting in thru the loose window.
I still haven't found the plugs to drain the door. I noticed my trunk had about 3'' of water in the spare well and the car was detailed last month and not sure if the detailer did it when he shampooed the trunk carpet.
abfhand is offline   Reply With Quote
Old 11-05-2007, 05:09 PM   #14 (permalink)
Has anyone had trouble with the trunk light assembly? I tried taking the bulb out to dry out the trunk and the little holders fell out. The trunk button in the glove box don't work now. Not sure that has anything to do with it... thanks.
Old 11-06-2007, 12:42 AM   #15 (permalink)
Zee
I didn't find any drain plug for the door, but merely pull the tims moulding out from the body a little and the water will drain.
You trunk probably had water in the well for some time. I believe there is a plug there you can remove.
