oil leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2007, 01:20 PM   #1 (permalink)
View hamelpe's Photo Gallery
oil leak
I have a 96 avalon its leaking oil just under the oil filter. The filter is tight but it still leaks oil any ideas?
Paul
hamelpe is offline   Reply With Quote
Old 03-25-2007, 02:16 PM   #2 (permalink)
update to oil leak
It looks like the leak is from the lower left bolt that supports the front engine mount. Does this bolt go through to the oil pan. What is the best method to seal this type of leak?
Paul
Old 03-26-2007, 01:28 PM   #3 (permalink)
View toyomoho's Photo Gallery
Check to see if this engine has an oil cooler pickup under the filter. You can tell because there will be a couple of hoses running out. If so, the leak could be from the pickup plate that mounts under the filter.
Old 03-26-2007, 04:46 PM   #4 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
Your front motor mount also has fluid in it that looks like oil. If the rubber is deteriorated then the mount may be leaking.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Oil Leak when Accelerating??? renmike 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-08-2006 08:41 PM
1990 oil leak poorlady 1st & 2nd Generation (1983–1986 & 1987-1991) 7 08-29-2006 08:44 AM
oil leak! help! matrix37495 Tercel, Paseo, Starlet, and Sera Forum 7 05-28-2005 10:49 PM
Oil Leak possibilities jsandek Camry & Solara Lounge 7 02-28-2005 01:29 PM
Me and my oil leak -- help! jawhie Celica Forum 11 01-10-2005 09:51 AM
