Transmission Slips/Rough Shifting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2007, 01:03 PM   #1 (permalink)
CNF - VA
View fallecker001's Photo Gallery
I just bought a 1999 Toyota Avalon XLS, 3.0L V6 Automatic with 106K miles. After driving it around for the past week or so, I have been noticing that the transmission is hesitating, slipping, or even shifting roughly at times. Many times when driving slowly through the neighborhood, I let off the gas, coast a little, and when I press the gas again, it hesitates slightly before it "clunks" back and I feel it pulling again. It never goes out of gear, and rpms don't rev high, but it just doesn't seem right.
Also, when I am slowing down, coming to a stoplight, it seems to wait too long before downshifting into the next lower gear. It almost loads up, then clunks down into the next gear.
Other times, when accelerating slightly, below 40mph, it just shifts roughly between gears. I expected much smoother shifting in an Avalon. On the Highway, it's all fine, I just notice this at lower speeds.
I have read a lot of the posts about transmission problems, but so far, none of them sound exactly like what I am experiencing. Can anyone help? Do you think I need a Tranny Fluid and Filter Change? Could it be a sensor or some sort of electronic problem??
Thanks,
CNF-VA
fallecker001 is offline   Reply With Quote
Old 03-27-2007, 02:18 PM   #2 (permalink)
smuook's Avatar
View smuook's Photo Gallery
I don't have this problem but you might want to look here... they seem to have endless threads about similar issues:
http://townhall-talk.edmunds.com/dir...index=.ef2150b
smuook is offline   Reply With Quote
Old 03-28-2007, 06:10 PM   #3 (permalink)
View funnysam's Photo Gallery
2nd Generation
i used to have this problem even after using Mobil One...
but after going for 10k and realized i over-filled it, i drain some and make sure the level is just in between hot max and min (right after getting to working temperature, around 5mi i think.) I ran for 300mi afterwards and the ride is now extremly smooth smooth.
me and my avi..
funnysam is offline   Reply With Quote
Old 03-30-2007, 12:55 PM   #4 (permalink)
CNF - VA
Thanks for the tips guys.
I checked the tranny fluid level and it seems just fine. Right where it should be.
Guess I'll just take it to the dealership and see what they have to say.
Thanks Again,
CNF-VA
Old 04-11-2007, 12:14 PM   #5 (permalink)
CNF - VA
Rough Shifting
FYI:
Got a Tranny Fluid Flush and all seems to be working much better now. I guess it was due, as my car has 109,000 miles on it!!
Thanks for the tips!
CNF-VA
Manual transmission rough shifting jbaib 1st Generation (1995.5–2004) 7 04-23-2007 09:16 PM
Found a $350 camry, but not sure if i can fix it Figit090 1st & 2nd Generation (1983–1986 & 1987-1991) 37 01-02-2007 02:29 PM
harsh shifting with automatic transmission crispie 3rd & 4th Generation (1992–1996 & 1997–2001) 15 11-01-2006 01:20 PM
94 Transmission Shifting Late paulcalif 3rd & 4th Generation (1992–1996 & 1997–2001) 27 08-15-2006 05:55 PM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 10:06 AM
