1998 Avalon A/C Issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-05-2007, 03:14 PM   #1 (permalink)
View ignoreme's Photo Gallery
About a month ago I started having some A/C issues with my 1998 Avalon. If I turn on the fan and press the A/C button the light turns on for a split second and nothing happens. If I turn on the fan, press and hold the A/C button the light will come on and the A/C will start up and the air gets cold. As soon as I release the button the light goes off, the A/C will shut down, and the air starts getting warm again.
My first through was that I needed to recharge the A/C, but since the A/C wouldn't stay on I didn't know how to do this. I then read that sometimes the pressure could be so low that it wouldn't accept a recharge and that you would need to disconnect the pressure switch connector and put a paper clip between the 1 and 4 terminal's to do the charge then reattach it when done.
I disconnected the pressure switch and inserted the paper clip in the correct terminals, attached the can of Freon, started up the car, and pressed the A/C button. There was no change in its actions and it wouldn't stay on. I tried holding in the button so the A/C would turn on, and I did this for a few minutes, and then went back to check the bottle of Freon. The bottle was barely cool, so I don't think it was doing much.
So I am not sure what to do from here. I am in no way an expert in this area, so any help would be truly appreciated.
ignoreme is offline   Reply With Quote
Old 04-11-2007, 10:28 AM   #2 (permalink)
View zirconx's Photo Gallery
I think you're going to need to take it to a shop. There could be a lot of different problems.
When I filled mine it was a completely empty system, but didn't have any problems with the low pressure switch.
Have you tested your high pressure switch? Maybe thats whats bad - the compressor starts to run but the high pressure switch doesn't turn on/off, so the system thinks something is wrong and turns off the compressor.
zirconx is offline   Reply With Quote
Old 04-11-2007, 10:47 AM   #3 (permalink)
View toyomoho's Photo Gallery
Check to see if the A/C system has a sight glass near the dryer. This would allow you to see the Freon inside the system and check for air bubbles when operating, a sign of low fluid.
camry and avalon reyrey127 5th & 6th Generation (2002-2006 & 2007-2011) 61 04-16-2007 07:19 PM
New Avalon tire wear issues rbarbot 3rd Generation (2005-2012) 4 01-19-2007 06:32 PM
Power Window on 1998 Avalon vairpack77 1st Generation (1995-1999) 2 11-20-2005 05:17 PM
New 2005 Toyota Avalon Unveiled! Ratko Toyota News 64 05-04-2005 12:14 AM
