Speaker Quality? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2007, 10:10 PM   #1 (permalink)
View DeclanFay's Photo Gallery
Speaker Quality?
the speakers in my son's 95 avalon seem very very questionable. The headunit is an aftermarket Alpine 9856 and when the volume is set past 6 or 7 (even with bass and treble at 0) the speakers start to crackle & distort. what could be causing this? are the speakers being overpowered?
any help would be great
DeclanFay is offline   Reply With Quote
Old 04-20-2007, 09:14 AM   #2 (permalink)
View aigochamaloh's Photo Gallery
the factory speakers are powered by a factory amplifier, so probably when you got your alpine installed, a amplifier integration harness was used. basically, you can't change the levels set into the factory amplifier, so it is very easy to distort the sound when using an aftermarket headunit.
solution is to cut out the factory amp all together and directly wire your speakers to the headunit. or get a new amp, cause it'll sound muchhhhhhhhhh better.
aigochamaloh is offline   Reply With Quote
Old 04-22-2007, 12:00 AM   #3 (permalink)
BANNED
View w203's Photo Gallery
The signal is not getting clearly to the speakers, so its either the amp or the speakers. The stock speakers aren't known to be crystal clear so that doesn't help either. You can either as mentioned above bypass the amp and not use it by routing the wires directly to the speakers or by adding an aftermarket amp.
w203 is offline   Reply With Quote
Old 04-22-2007, 04:15 PM   #4 (permalink)
if i buy new speakers and add an aftermarket amp would somewhere like bestbuy or circuit city be able to bypass my factory amp for me?
Old 04-23-2007, 12:21 AM   #5 (permalink)
BANNED
They should, its pretty simple. They might not do it if you don't buy from them but I have no idea so I would ask beforehand. Too bad your located in Chicago.
Gen 5 Camry XLE Speaker Upgrade Convert Audio, Video, and Security - Tech 28 05-05-2008 01:51 PM
Avalon shows dent in Toyota quality sciguy0504 Toyota News 98 03-25-2007 11:49 PM
DIY: AE92 Right-Front Speaker emiliorescigno Archived Corolla threads 13 03-29-2006 09:43 PM
Getting my amp to turn off with my stock head unit Waterwookiee Audio, Video, and Security - Tech 10 03-22-2006 01:00 PM
What size speaker in 2005 Camry LE?!?! Cyberhwk Audio, Video, and Security - Tech 6 01-27-2005 08:46 AM
