overdrive - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2007, 09:04 PM   #1 (permalink)
View jon456's Photo Gallery
overdrive
I have a 98 Avalon XLS and I was wondering when I should have overdrive on and when it should be off. I like accelerating fast, if overdrive is on will that affect acceleration?
jon456 is offline   Reply With Quote
Old 05-14-2007, 09:20 PM   #2 (permalink)
View toyomoho's Photo Gallery
The O/D should have coolant temp and MPH lockouts below which it does not operate. If the O/D is engaged and your press the gas pedal down, the trans should "kick down" (overdrive turn off).
Read the additional posts at the bottom of this page.
Old 05-15-2007, 08:42 AM   #3 (permalink)
'07 Avalon Limited
Tom in Tacoma's Avatar
Gameroom cash: $354645
View Tom in Tacoma's Photo Gallery
OD does not have any affect on acceleration. It doesn't even come into play until you're running up to speed.
Tom in Tacoma is offline   Reply With Quote
Old 05-15-2007, 12:41 PM   #4 (permalink)
View NYLexSC's Photo Gallery
I'm guessing the 98 Avalon had 4 forward gears? If that's the case, O/D ON simply means that the 4th gear is used. If you keep O/D off, the car will never upshift into 4th gear, and will run 3rd gear at all speeds. There is never really any reason to turn O/D off unless you are in some situation that requires you to keep going between 30-45 mph rather quickly, then you should turn O/D off to prevent all the gear shifting that would occur when you take your foot off the gas/put it back on. Under 30mph generally makes no matter as the car generally won't upshift to 4th gear until you are over 35mph and no longer accelerating.
The other time you can turn O/D OFF is on the highway. If you know you are going to pass someone as soon as there is room, you can turn O/D OFF in advance to kick down to 3rd gear. This way when the room is there, you can punch it and go right away without waiting for the downshift. Then simply turn O/D back on to go back to 4th gear after you make the pass.
NYLexSC is offline   Reply With Quote
Old 03-02-2008, 07:13 PM   #5 (permalink)
View CharlieAVLN's Photo Gallery
On my '96, I find it annoying when, going up a steep, long highway grade, it keeps fluctuating back and forth between 3rd and O/D. So, I simply turn it off in this situation. Also makes it a cinch to zip by everyone else puttering up the grade!!!!
CharlieAVLN is offline   Reply With Quote
Old 03-04-2008, 02:49 PM   #6 (permalink)
Napa Burgundy '98 Avy
View cexsiman's Photo Gallery
there isnt much power down low in the powerband anyway, so like everyone said, it makes no difference (except in gas mileage) to have off when driving in most cases. i would say to just hit the ECT Power, it will keep you in your current gear a little longer giving you the power you are looking for, and personally i feel that the car is a better performer with ECT engaged versus o/d off.
cexsiman is offline   Reply With Quote
Overdrive switch - '03 Echo (Auto trans.) jlift Yaris, Vitz and Echo Forum 4 12-18-2006 07:03 PM
overdrive light blinks occasionally Bill in SC Camry & Solara Lounge 5 10-22-2005 09:35 AM
About overdrive wraith_nv Camry & Solara Lounge 5 04-12-2004 01:35 AM
To Overdrive or Not To Overdrive DrewsCam Camry & Solara Lounge 4 04-02-2004 06:14 PM
No Overdrive anymore... TakeABao Camry & Solara Lounge 26 12-12-2003 02:26 PM
