Originally Posted by steve326a
Why do you want to disable it? It doesn't get in your way at all. It won't lock your car automatically unless you unlock it remotely and don't open a door within 30 sec. If you only use a key, it disables alarm immediately as you turn the key to unlock it. Again, why disable it?
Didn't realize this got a response, sorry.
It's interfering with the remote start system I have currently installed (Bulldog Security Deluxe 200B I think). It starts every once in a while, but sometimes, it won't start, but it'll set off the alarm instead, with the only solution being running out to the car and putting in the key. My brother and I installed it... wiring should be right. I may have to check it, but it should be right. I double-checked the entire way.
