OBD II code P-0500 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-20-2007, 12:36 PM   #1 (permalink)
View Jagalag's Photo Gallery
Gen1 OBD II code P-0500
I heard sort of a farting sound coming from the car when I was backing out of a parking spot yesterday... followed by the MIL lamp coming on steady. Ran the code, and it showed P-0500 which was a vehicle speed sensor malfunction. I didn't clear it, drove my car today... the telltale sign of a serious problem for this code I'm told is the speedometer not working properly. No problem there, and the light went out after about 5 cycles. Any idea how this might happen and how it automatically fixed itself?
Jagalag is offline   Reply With Quote
Old 06-20-2007, 12:53 PM   #2 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
Temporary glitch i suppose. It does happen some times. Usually when connector gets shifted around or you get a little moisture past the seal in a connector. If it dosent come back regularly I would worry about it too much.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 06-20-2007, 01:20 PM   #3 (permalink)
View Mike Murrell's Photo Gallery
http://www.obd-codes.com/trouble_cod...alfunction.php
Mike Murrell is offline   Reply With Quote
Old 06-20-2007, 04:48 PM   #4 (permalink)
View toyomoho's Photo Gallery
The ECM needs two driving trips with the sensor malfunction to set the check engine light. If speedo is not working OK, the sensor is not working normally. Keep an eye on the speedo.
Old 06-24-2007, 06:30 AM   #5 (permalink)
Thanks to all who replied, the MIL didn't come back on, so I think it must have been a one time electrical gremlin, don't know... I'll have my mechanic look at it when I take it to the shop next time.
OBD II PO446 Code JKP T-100 2 07-19-2008 09:17 PM
OBD II P1121 Code '99 Land Cruiser bigdz Land Cruiser Forum 1 03-11-2005 06:37 PM
OBD II Code 0440 larryk Camry & Solara Lounge 0 02-12-2005 02:51 PM
