'95 Air Cond. Warm Air - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2007, 07:53 AM   #1 (permalink)
View bperry's Photo Gallery
Gen1 '95 Air Cond. Warm Air
My '95 has a weird issue. It'll blow ice cold air at first, then after a while I lose it. The a/c switch is still lit and the blower keeps going, but no cold air and no "conditioning." When this happens the windows start to fog as a result.
Also, I think there is an odor of oil from the engine compartment and the vents but it's not motor oil.
When I restart after a couple of hours or next day, then ice cold air is there again.
Any help is appreciated.
bperry is offline   Reply With Quote
Old 06-30-2007, 02:58 PM   #2 (permalink)
View 1995AvaIon's Photo Gallery
I did a semi-search so I don't know if this will help you or not, but it's probably your expansion valve. If your expansion valve is frozen over, it can't let out cold air properly. or you have low freon.
1995AvaIon is offline   Reply With Quote
Old 07-09-2009, 01:22 PM   #3 (permalink)
View Blockheadd's Photo Gallery
i know this is 2 years old, but.. an expansion valve doesn't "let out cold air". it's just a metering device to vary the amount of refrigerant it allows through depending on the temperature of the suction line.
Blockheadd is offline   Reply With Quote
AC problems, please help (Warm air) Nuke209 3rd & 4th Generation (1992–1996 & 1997–2001) 10 07-01-2007 06:57 AM
K&N air filter vs K&N cold air intake dsulu 89-95 Toyota Pickup/Hilux 12 01-14-2007 12:04 PM
Camry 95 Air Con intermittent ianm 3rd & 4th Generation (1992–1996 & 1997–2001) 1 08-13-2006 03:47 PM
The best Air Intake for a 95 Camry V6LE 3rd & 4th Generation (1992–1996 & 1997–2001) 10 03-19-2003 11:50 PM
Does warm air always blow in your car? Nate Camry & Solara Lounge 5 03-26-2002 12:52 AM
