99' Avalon Stereo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-12-2007, 12:44 PM   #1 (permalink)
View TerminatioN's Photo Gallery
99' Avalon Stereo
Hello, I have a 1999 Avalon with the premium stereo system that has the sub in the back.
I was thinking about upgrading my stereo system, but I don't know much about that kind of stuff. But a friend of mine does and he's been helping me. But there is one thing we're having problems figuring out. We were browsing around and read somewhere that there is a built in amp that powers the sub in the back.
Want I am wanting to do is replace the head unit with an aftermarket one and still be able to use the sub without buying anything else.
So my question is, if I replace just the headunit can I still use the sub without buying an aftermarket amp or anything else too expensive? If so, how would I go about doing this?
Thanks in Advance.
TerminatioN is offline   Reply With Quote
Old 07-17-2007, 10:40 AM   #2 (permalink)
So no one has any knowledge about this?
Old 07-17-2007, 05:14 PM   #3 (permalink)
View jon456's Photo Gallery
I am not 100% sure, but I would guess so. Why would you want to get a new headunit? The headunit is decent and the spearkers aren't bad. The sub is garbage though, I got 2 MTX without getting a new headunit or speakers.
jon456 is offline   Reply With Quote
Old 07-18-2007, 01:25 AM   #4 (permalink)
WHAT???
View supra06's Photo Gallery
TerminatoN, u can get a wiring harness from Circuit City called Metra 70-8121 or 12, its plug and play, very easy, it works great for mine, and yes u can still use ur factory SUB, mine is blown but it still works, planning on getting subs
supra06 is offline   Reply With Quote
Old 07-18-2007, 05:11 PM   #5 (permalink)
Its decent, but its not very loud and the quality is crap at times. Plus mine is in pretty bad condition and looks terrible.
The plan on replacing the sub eventually as well, but its not my main priority, since I only listen to rock, I don't need a lot of bass.
I'm getting a Pioneer DEH-P80MP and four 4" Rock Fosgate T142C's. I'll let you guys know how it turns out. I'll also be purchasing a CD-IB100II adapter for my iPod.
Old 07-18-2007, 07:30 PM   #6 (permalink)
Napa Burgundy '98 Avy
View cexsiman's Photo Gallery
jon456, how did you wire in the subs? did you also buy an amp? do they sound the same/better/worse than stock? what kind of box are they in?
cexsiman is offline   Reply With Quote
Old 07-18-2007, 11:05 PM   #7 (permalink)
Anyone know how big the sub is in the back of a 99 Avalon? 6"? 8"?
Old 07-18-2007, 11:54 PM   #8 (permalink)
WHAT???
8" i think, and yes JON, tell us
Old 07-19-2007, 02:14 AM   #9 (permalink)
Circuit city wired it for 70 bucks I think. I bought a bass package which came with 2 12" mtx and an mtx amp. It was 300, I got a 4 year warranty. After everything it ending up being like 550. The sub in there now is garbage. And yes, my car bumps now. If you listen to a lot of rap I suggest it, but if you don't like a lot of bass then its not worht the cash. And I have the stock headunit. Everything works well, no problems yet, however stuff rattles. I had to put foam under teh stock sub box, because that rattled. The trunk rattles however you can't hear it up front. The back seats are messagers. If the windows are down you really can't hear the rattling though.
Old 07-19-2007, 08:55 AM   #10 (permalink)
WHAT???
anyone how much CC charge just for installation? or do u have to buy something?
Old 07-19-2007, 10:41 PM   #11 (permalink)
WHAT???
so today i switch out my HU and now it doesnt power on, i wired it the same way. its a kenwood kdc-x790 i dont know if im suppose to wire this HU in a diff. way or not, could anyone tell me what went wrong? fuse? i checked the fuse on the left side by the driver door its fine.
thanks.
Old 07-20-2007, 12:25 AM   #12 (permalink)
thanks.
Don't hijack my thread please.
Old 10-23-2008, 12:34 PM   #13 (permalink)
View Finnish_Fox's Photo Gallery
Hi all...
I've got an 1999 Avalon XLS and factory installed stero unit is broken (volume knob is gone, cd player broken). I have the 7 speaker set, inclusive of the sub in the back. (4 on front doors including tweeters, 2 on back doors, 1 bass behind back seat)
I am looking to replace it with an Alpine CDA-9884. Does anyone know iwhat issues I may run into?
How do I remove the trim from around the ignition on the XLS?
Will I need to purchase a seperate amp for the sub or will the correct wiring harness allow me to "plug and play"?
Any help is greatly appreciated...
Finnish_Fox is offline   Reply With Quote
Old 10-23-2008, 01:00 PM   #14 (permalink)
View sseaman's Photo Gallery
sorry i'm not much help, i replaced my with another factory unit
06 Lexus IS250
04 Toyota Sequoia 4x4 Ltd
sseaman is offline   Reply With Quote
Old 10-23-2008, 02:12 PM   #15 (permalink)
Originally Posted by Finnish_Fox View Post
Hi all...
Wow, this is over a year old thread, you're lucky I'm subscribed to this thread.
Anyways, you shouldn't have an problems with any aftermarket stereo. The sub should work find, it should all be "plug and play". It won't sound like an aftermarket sub and amp, but it will sound the same (if not a little bit better) than it was with the stock head unit.
To take the trim off you kind of just have to pry it off. Its held in with tabs. I'd suggest getting one of those orange tool kits from Walmart, in there is a tool to help you take the trim off. Basically its just a tool to help you get under it and gain leverage to pull it off. Like I said, its just held in with tabs, no screws or anything, so its quite easy. Once the trim is off you'll see four screws holding the headunit it, unscrew those and you're good to go.
Just make sure that when you put the trim back on you reconnect the four way flasher button, air conditioning buttons and the tubs thats next to the ignition.
History of the Toyota Avalon Ratko 1st Generation (1995-1999) 6 04-01-2012 09:05 AM
99 Avalon stereo inputs Gene13 1st Generation (1995-1999) 2 04-07-2007 11:47 AM
Aftermarket Stereo in 2006 Avalon crowemojo 1st Generation (1995-1999) 15 06-13-2006 10:35 PM
Coupla Questions on 97 Avalon Stereo Replacement bobcrane Audio, Video, and Security - Tech 5 10-08-2005 04:12 PM
96 avalon stereo? Underhill 1st Generation (1995-1999) 3 01-29-2003 05:46 PM
