Rack & Pinion - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-16-2007, 05:45 PM   #1 (permalink)
View 97ava's Photo Gallery
Rack & Pinion
I see alot of members complain when they have to replace their rack & pinion, what are some common signs that the rack & pinion is going bad?
97ava is offline   Reply With Quote
Old 08-18-2007, 12:16 PM   #2 (permalink)
View toyomoho's Photo Gallery
The ends of the rack housing have bushings and oil seals that can wear out and cause excess fluid leakage or rake endplay. The rack itself can have damaged or worn teeth resulting in hard steering wheel rotation in spots or excess steering play.
Before blaming the rack and pinion, make sure all the other steering and suspension components are in good shape.
Read the posts at the bottom of this page for more input.
Old 08-21-2007, 07:18 PM   #3 (permalink)
View pedro2u's Photo Gallery
I was just searching for a power steering fluid leak, there were no other symptoms. Steering was fine, but it was the rack leaking
pedro2u is offline   Reply With Quote
Rack & pinion and 2 Axels Replaced! 73sport 3rd & 4th Generation (1992–1996 & 1997–2001) 16 07-18-2010 12:24 AM
Replace rack and pinion 1996 Avalon TMack409 1st Generation (1995-1999) 2 02-12-2007 03:34 PM
Stealership wants to replace rack & pinion - 2003 LE w/ 55K bcnland 5th & 6th Generation (2002-2006 & 2007-2011) 8 10-08-2005 09:37 AM
Rack and pinion replacement? rh8746 Celica Forum 4 08-15-2005 10:29 PM
