95 Avalon AC problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-18-2007, 09:49 PM   #1 (permalink)
View Ivory Tickler's Photo Gallery
I have a 95 Avalon - nice car - a problem with the AC - sometimes it works great with plenty of cold air - then all of a sudden the cold air will stop. I can't quite figure out a pattern to this. Sometimes it will go an hour before the cold air quits, and sometimes it quits within just a few minutes.
One mechanic thought the compressor was getting "weak," but f that's true why would it work great sometimes? Another mentioned the expansion valve - very expensive repair since the dash has to be pulled out. Maybe it's just a short in an electrical wire somewhere. Any ideas on what could be the problem?
Ivory Tickler is offline   Reply With Quote
Old 08-19-2007, 12:33 AM   #2 (permalink)
View jon456's Photo Gallery
Yep, I thought the exact same thing with my 98. Just a short or something. Would work randomly then shut off for days sometiems. The AC amp needed to be replaced. Toyota wanted 1100 bucks, but I took it elsewhere for 600. Still a rediculously expensive repair and a bullshit problem.
jon456 is offline   Reply With Quote
Old 08-20-2007, 05:09 PM   #3 (permalink)
TomC
View avalontom's Photo Gallery
Ivory,
I've read that a low refrigerant level can cause your problem. I would have your a/c looked at by a qualified technician.
Good luck.
Tom
avalontom is offline   Reply With Quote
Old 11-05-2007, 05:08 PM   #4 (permalink)
View abfhand's Photo Gallery
AC Problem
I have a 98 avalon and there were many tech bulletins on the ac cutting out. Finally, the dealer haggled with toyota and toyota sprung for the parts. cost me 250 for the install. 900.00 if it were install and parts.
abfhand is offline   Reply With Quote
Old 11-07-2007, 04:26 PM   #5 (permalink)
Got this from another group. This is what my problem was. The dealer had to bump heads with the toyota rep to okay the 800.00 parts...
This is a very common problem on all late 90's avalons with auto a/c. Common symptoms include:
=A/C int. INOP
=The Ambient Temperature display goes blank or displays "-"
=Fresh/Recirc indicator light INOP
=Mode Indicator Light Inop
=Blower Indicator Light Inop
The Fix for this involves replacing
A/C Amplifier (ECU) Part #88650-41030
Air Inlet Servo Motor Part #87106-07050
Servo Link Part #87151-07010
Labor under warranty payed 2.7hrs If you go to a dealer under CP expect to pay 5 Hrs Labor.
95 Avalon Power window problem krispykreme 1st Generation (1995-1999) 3 01-01-2007 10:45 PM
ac problem alexh Camry & Solara Lounge 1 06-21-2006 11:57 AM
AC Problem Diagonsis toyoonly Camry & Solara Lounge 10 12-08-2005 09:47 AM
AC Problem Damith Camry & Solara Lounge 2 11-10-2005 05:29 AM
95 Avalon Check Engine Light and Flashing OD Light teke175 1st Generation (1995-1999) 0 04-27-2005 10:17 AM
