How Hard to Inspect Timing Belt on '98 Avy? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2007, 11:58 AM   #1 (permalink)
View leadsled toy's Photo Gallery
I just picked up this XLS Avy ('98) w/ 115k miles.
How hard is it to inspect the timing belt and 'see' if it's been replaced or not? I hear they suggest a change at 90k miles and I have NO IDEA if it's been done or not.
Thanks all!
1998 Toyota Avalon XLS
160k miles and counting w/o major maintenance required.
Pads/ Rotors/ Timing Belt/ Plugs Only!
leadsled toy is offline   Reply With Quote
Old 08-24-2007, 05:03 PM   #2 (permalink)
TomC
View avalontom's Photo Gallery
LT,
When the dealer replaced the timing belt on my '95 they put a sticker on top for the cover on the right side.
The sticker comes with the factory timing belt. If no sticker on your car, it's probably safe to assume the belt has never been changed. Abelt failure will leave you stranded but will not cause engine damage.
Tom
avalontom is offline   Reply With Quote
Old 08-24-2007, 07:08 PM   #3 (permalink)
View toyomoho's Photo Gallery
If no sticker, try looking at the front of the engine to see if the covers have been removed. Unless the belt is damaged, has oil on it from a bad seal, etc. it is almost impossible to tell belt mileage by looking at it.
Old 08-27-2007, 07:39 AM   #4 (permalink)
Ok, I'll check for a sticker. I don't believe it has one and I'd be surprised if they changed it anyway, but ran it longer avoiding a belt change.
How do I know if the covers have been off? Sealant missing?
Old 08-27-2007, 03:10 PM   #5 (permalink)
Replacing the belt requires removing the plastic covers on the front of the engine. No sealant but rubber gaskets between the cover edges and engine. Look for bolts, etc. that have indications of removal.
Old 08-27-2007, 03:53 PM   #6 (permalink)
Ok. Gotcha. Thanks very much!
Old 08-30-2007, 11:15 PM   #7 (permalink)
silverxls's Avatar
View silverxls's Photo Gallery
if you're going to go thru all the work to take off the covers to look at the belt, you may as well just change it while you're there.....that's 90 percent of the work.
silverxls is offline   Reply With Quote
Old 08-31-2007, 08:00 AM   #8 (permalink)
No kidding? It's not that bad to DIY? I am mechanical but used to V8 RWD's.....
Old 09-05-2007, 12:43 PM   #9 (permalink)
silverxls's Avatar
it's not that bad of a job. biggest time is spent removing all the things to get to the point that the covers can be removed, such as alternator and brackets, tire and piece of fender liner, engine mounts etc. once your at this point, removing covers and changing belt is not hard. i've done the job in about 8 hours. a couple more things.... usually they will replace the water pump just because you've already gone thru all this work to get in there and it's good preventive. i would reccomend that, but more importantly is to replace the idler pulleys while your there. i helped a friend do this job, and he wouldnt spring for the extra 50 bucks for the pulleys, and in less than 40k miles after the change, the bearings went out in one of them and of course ruined the belt and had to do the whole job over.
Old 09-05-2007, 02:07 PM   #10 (permalink)
How much of an issue is it aligning everything w/ the new belt? I was concerned over multiple cam alignment etc.
Old 09-05-2007, 09:44 PM   #11 (permalink)
wonger's Avatar
View wonger's Photo Gallery
the cams both have marks .. and so do the belt
i do v6 toyotas easy.. lol i love them since it only takes me 3-45 mins hehe
next time i do one.. if i remember ill take pictures..
wonger is offline   Reply With Quote
Old 09-06-2007, 07:21 AM   #12 (permalink)
I'd love to see pictures- it'd be a great help in guiding me. Thanks.
Old 09-06-2007, 07:38 AM   #13 (permalink)
The cam pulleys have marks, etc to line up. Before taking things apart set the crank at 0 degrees with number one cylinder at TDC. After the covers are removed see how the pulleys line up. Might highlight the marks with a pin used junk yard use to mark parts. Take photos if possible or record info as to how the belt wraps around the various items such as cam pulleys, idlers, etc.
Once the new belt is installed, rotate the crank at 2 times CW by hand and recheck the marks. Make sure the marks are still lined up!
If doing it for the first time, expect to spend a full day at it.
Old 09-07-2007, 02:09 AM   #14 (permalink)
wonger's Avatar
top belt has solid lines and the bottom line is dotted
i know there are arrows on the belt and they should point away from the engine.. ( pointed at you if you if your facing it)
Old 09-07-2007, 06:31 AM   #15 (permalink)
Autobots ( toyota )
wolverine10's Avatar
View wolverine10's Photo Gallery
wow! thats really heplful! thanks for that!
What if the problem is this? The fuel on the tank get easily drain? what would be the problem!?
Rule #8.
No commercial/business/website promotion in Signatures. The only URL's allowed in signatures are to your own car's personal website.
wolverine10 is offline   Reply With Quote
DIY V6 Timing Belt Replacement Variety=Spice 1st & 2nd Generation (1983–1986 & 1987-1991) 13 09-02-2009 11:09 PM
Engine wont start... slipped timing belt? PoR2GeEzCamry 1st & 2nd Generation (1983–1986 & 1987-1991) 24 08-12-2007 03:23 PM
91 Camry How hard to change timing belt? jefe 1st & 2nd Generation (1983–1986 & 1987-1991) 1 11-19-2004 05:56 PM
98 Camry Timing Belt Pictures Crusader7 3rd & 4th Generation (1992–1996 & 1997–2001) 4 08-26-2003 06:24 PM
