99 Avalon How Often do I need to change timing belt? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2007, 02:50 PM   #1 (permalink)
View cato47's Photo Gallery
Hello:
I'm getting ready to buy a 99 Avalon XL in pristeen condition with 123K miles for $4500. It's never had a timing belt. I'm wondering at what milage increments the belt should be changed?
Rick
cato47 is offline   Reply With Quote
Old 08-29-2007, 03:40 PM   #2 (permalink)
TomC
View avalontom's Photo Gallery
Cato,
90,000 miles or about 5 years, whichever comes first.
Tom
avalontom is offline   Reply With Quote
Old 08-30-2007, 11:10 PM   #3 (permalink)
silverxls's Avatar
View silverxls's Photo Gallery
in 99 the service manual calls for timing belt at 60k miles. in 00 they changed to 90k. the typical belt will last more than 100k, but you should plan on doing it right away., dont push fate. if you start watching online you may find a service special at a dealer near you. they run a special in this area about every 6 months and you can get it done for around $199, but this is only available if you find the special and a coupon online. if you just call the service dept. they won't give you the special price.
silverxls is offline   Reply With Quote
Old 09-01-2007, 01:41 PM   #4 (permalink)
View tracerich's Photo Gallery
The problem with the $199 special is, thats only for a belt. What about the water pump, tensioner, idler pulleys and seals? Do you think that those components are going to outlive the second belt replacements life? It does not make sense to just replace the belt, as you are in there doing the belt, it is only a little bit more labor, and the cost of the added parts to incur. I would not recommend replacing a belt only. Three months later the idler goes bad and it all has to come back apart? You'll be wishing you changed it all when you had it apart.
tracerich is offline   Reply With Quote
Old 09-02-2007, 06:20 PM   #5 (permalink)
wonger's Avatar
View wonger's Photo Gallery
when you ahve someone replace your t-belt they will be checking and trying to upsell more than just a belt..
but if you lived closer i could do it for that special .. hehe
wonger is offline   Reply With Quote
Old 09-02-2007, 10:14 PM   #6 (permalink)
2000-Avalon's Avatar
View 2000-Avalon's Photo Gallery
Honestly,
on my 2000 avalon I got about 125k on the original timing belt. I had the dealership look at it and the guy said its perfectly fine.
2000-Avalon is offline   Reply With Quote
Old 09-05-2007, 12:59 PM   #7 (permalink)
silverxls's Avatar
i do definately agree with changing idlers and tensioners and such, but starting at 199 and adding is better than starting at 399 and adding...
Timing Belt - 99 4runner - Replace or Not cedargrove 4Runner Lounge 14 01-21-2012 11:05 AM
97 avalon timing belt ausmhow 1st Generation (1995-1999) 3 03-26-2007 10:51 PM
99 Corolla--Timing Belt Z-Man99 Archived Corolla threads 0 03-27-2006 09:26 PM
When to change Timing Belt ? Morley Camry & Solara Lounge 14 04-24-2005 02:32 PM
99 Camry Timining Belt for $179 DeafBug Camry & Solara Lounge 9 03-07-2005 10:56 AM
