the rear seats in the avalon all have 3 point over the shoulder belts. from what i understand, your center belt has retracted all the way to the top? did a bolt come out with it or you just have the metal bracket for the belt come up?
anyway, it's as easy as pulling up the seat cushion. it's anchored in 3 points; the center, left, and right. if you were sitting in each seat, it'll be right between your legs. if you pull hard enough at the edge, it should come right up. then you can check out what happened...
