Could I have a Security Module Problem on '98 Avy? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2007, 06:46 AM   #1 (permalink)
View leadsled toy's Photo Gallery
My key FOB works intermittently. Could it be a problem w/ the security module? The battery checks out fine. Any one have experience w/ this?
Also where is the sensor? Can I clean it?
1998 Toyota Avalon XLS
160k miles and counting w/o major maintenance required.
Pads/ Rotors/ Timing Belt/ Plugs Only!
leadsled toy is offline   Reply With Quote
Old 09-18-2007, 12:19 PM   #2 (permalink)
View toyomoho's Photo Gallery
Might be a dirty switch on the FOB causing intermediate contact.
Old 09-18-2007, 07:19 PM   #3 (permalink)
Is this something I can access and clean? If so, can you point me there?
Old 09-19-2007, 10:34 PM   #4 (permalink)
If there are other buttons on the FOB see if they all work, if only one button has a problem then the contact could be the issue. If all buttons don not work could be a battery, battery contact or as you state the cars theft protection system.
Not sure if the unit can be taken apart or how.
Also do a TN search; the issues of FOB and Toyota security systems not working or working strangely does come up from time to time.
Old 09-19-2007, 10:44 PM   #5 (permalink)
Thanks I'll check it out then.
How Hard to Inspect Timing Belt on '98 Avy? leadsled toy 1st Generation (1995-1999) 18 09-08-2007 06:27 PM
98 Avalon intermittent problem scalelar 1st Generation (1995-1999) 2 09-08-2007 08:07 AM
98 Corolla anti-theft Alarm problem deuce32s Archived Corolla threads 1 03-27-2007 10:09 AM
98 Camry LE Problem (Odometer stuck at 0) Prophecy 3rd & 4th Generation (1992–1996 & 1997–2001) 3 01-28-2004 01:58 AM
98 Camry with exhaust problem J-Racer 3rd & 4th Generation (1992–1996 & 1997–2001) 3 10-09-2003 08:23 AM
