1996 Long Term Fuel Trim - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2007, 12:37 PM   #1 (permalink)
View TMack409's Photo Gallery
I've always been curious about why Bank 1 seems a bit out of kilter with respect to bank 2's seemingly normal readings...but I am not throwing codes so I've never really dug into it very deeply.
Today I thought I would dig down a bit - with your help and perhaps find out what the deal is.
At idle, in neutral, the B1 LTFT reads -4.68. Then at almost exactly 1100RPM, the B1 LTFT drops quickly to -.87 and remains there thru out the rest of the RPM range.
The mysterious 1100 RPM remains the consistent shift point.....in neutral......
However, when I put the car in D with foot on the brake and then the shift from -4.68 to -.87 occurs with even the slightest application of my foot on the gas pedal.
On the surface, this appears to be a vacuum leak. But that shift from -4.68 to -.87 is so quick and so sudden, that I am not so sure about a vacuum leak.
FYI - I swapped the Oxygen sensors around last year while messing with this "problem" and it made no difference.
Is there a known problem area with Bank1- Regards vacuum leak? Intake manifold? Fuel Injector seals? To be sure, I've checked all the vacuum hoses for leaks a dozen times or more.
Your thoughts?
TMack409 is offline   Reply With Quote
Old 09-15-2007, 04:35 PM   #2 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Your thoughts?
I think you're touched in the head and having too much fun with your scanner.
It's always been my experience on the *MZ-FE engines that when a genuine lean or rich condition is present, the system always detects it in bank 1 first (PO171, PO172), and I remember hearing a few other guys comment about it too over the years. But, I never cared, mostly because this little tidbit has no bearing on how the thing works in regards to it's use. There's probably an answer somewhere in the corner of the mind of an engine management software engineer in Japan, though.
As far as your fuel trim "problem", I think you should back away from the scanner and go to a ball game or something. Fuel trims under 8% or so either way are perfectly acceptable, and the condition you're describing is probably related to some preprogrammed response to a shift in calculated load. Or not. Either way, there's no point in probing for problems if you have no light or driveability concerns. Take up model rocketry or something. Build a kite.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 09-15-2007, 06:08 PM   #3 (permalink)
Thanks for the response Qslim! I have a full time hobby involving my 1985 Jaguar, but once in awhile I get caught up :-) That would have been today ;-)
Old 09-15-2007, 06:16 PM   #4 (permalink)
Qslim's Avatar
Hah! I bet it IS full time. I've heard Lucas makes (or made) only the best electrical systems...
-- Get him, boy....
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
Drifting on the streets of Long Beach(legally) onehotcamry General Discussion 0 02-25-2005 04:23 PM
Long Term Storage of my Cam Cello8619 Camry & Solara Lounge 1 10-13-2004 10:15 AM
Guide To Nitrous Sportivo Concepts Hardcore Tech and Competition 2 10-09-2003 03:25 PM
Long term parking near Toronto airport. benyu Off Topic 9 12-21-2001 11:37 PM
