need torque specs for intake plenum 97 avaoln - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2007, 08:07 PM   #1 (permalink)
View paul r's Photo Gallery
Hello everyone..Im new to this forum..just discoverd it!...and I need your help. I am renewing the valve cover gaskets and I need to know what the toque is for the valve cover bolts and also for the two hex nuts and two hex bolts for the intake plenum..Ps The front was easy to do and the rear...well you spend more time removing all thats above the rear cover..wasnt difficult..just time consuming...there is no need to remove the intake manifold..I got a new throttle body gasket and I also replaced the spark plugs..also cleaned the throttle body..Thank you kingdly for the torqe specs..PaulR..1997 avalon 70k miles!
paul r is offline   Reply With Quote
Old 09-16-2007, 11:35 PM   #2 (permalink)
wonger's Avatar
View wonger's Photo Gallery
Intake Manifold to Cylinder Head 11 ft.lb No. 1 Engine Hanger to Air Intake Chamber 29 ft.lb No. 1 Fuel Pipe to Intake Manifold 14 ft.lb Coolant Outlet to Intake Manifold 11 ft.lb
Throttle Body to Intake Intake Chamber 14 ft.lb
what this one below.. it says IN. Lbs not FOOT lbs
Cylinder Head Cover To Cylinder Head 69 in.lb
88 4Runner
wonger is offline   Reply With Quote
Old 09-17-2007, 06:54 AM   #3 (permalink)
thanks for torque specs
What about the plenum torque specs to the intake manifold..there are two nuts and two hex bolts?...thanks again!!!
Stock 97 Cam specs? Ruffrydasean 3rd & 4th Generation (1992–1996 & 1997–2001) 4 08-03-2004 08:09 PM
Axle torque specs CamryDX Camry & Solara Lounge 1 09-23-2003 07:07 AM
