Radio, Ambient temp, clock all went out! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2007, 03:06 PM   #1 (permalink)
View jon456's Photo Gallery
They all just shut off, I can't see the ambient temp, or the time. The radio doesn't turn on now. Everything else works. This just happened too, what can I do to fix it? It is a 98 XLS. Oh yeah, and the electrical outlet doesn't work either now.
jon456 is offline   Reply With Quote
Old 09-21-2007, 03:15 PM   #2 (permalink)
X Avalon
View hsakuragi's Photo Gallery
check ur fuse
The one and only Avalon SE Limited Edition in CA!
hsakuragi is offline   Reply With Quote
Old 09-21-2007, 03:23 PM   #3 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Check the fuse labeled 'CIG/RADIO'
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 09-21-2007, 03:45 PM   #4 (permalink)
Ok, the cig/radio fuse I found its location. How do I check if it is blown or not? And if it is blown how do I fix it?
Old 09-21-2007, 03:52 PM   #5 (permalink)
Qslim's Avatar
Pull that bastard out. When you look through it, you'll see a little piece of bent metal inside the plastic. If the metal is broken, the fuse is bad and needs to be replaced with one of the same color. Pull out an adjoining one too if you want and compare the two to see if they look different.
-- Get him, boy....
Changing the amber clock display color - DIY OtherHand 2nd Generation (2005+) 13 01-31-2008 09:43 AM
Radio, Dash Clock and Cigarette Lighter Went Out (Shorted) stevenjgarner 3rd & 4th Generation (1992–1996 & 1997–2001) 1 03-18-2007 03:05 AM
Corolla 1992 radio problems peptobysmol Archived Corolla threads 0 04-18-2006 10:17 PM
Radio Clock with Pic How to turn it on??? 94_v6_camry Archived Corolla threads 0 10-09-2004 10:24 PM
Toyota Corrola Clock Radio???? 94_v6_camry Archived Corolla threads 1 09-21-2004 10:29 AM
