Oil consumption question. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2007, 06:46 PM   #1 (permalink)
View Jagalag's Photo Gallery
Gen1 Oil consumption question.
I have a 99 Toyota Avalon XLS with 107,000 on it. I put in 5 quarts everytime, and I get back about 4 quarts every time, and this includes residual from the filter itself, save for maybe about 60-100 mls of spillage when the filter comes off. Is it burning up too much between changes, or does this sound about right?
Jagalag is offline   Reply With Quote
Old 10-03-2007, 07:17 PM   #2 (permalink)
View Mike Murrell's Photo Gallery
How many miles between oil changes?
Mike Murrell is offline   Reply With Quote
Old 10-04-2007, 09:38 AM   #3 (permalink)
Always 3,000.... give or take 100 miles.... none of that 7,000 miles owners manual advice. Always Castrol GTX 5W-30.
Old 10-04-2007, 10:51 AM   #4 (permalink)
I should have posted this reply as my first reply.
I'm not sure your technique is the way to go about determining if you are using/leaking oil.
Use the dipstick. Check it often. Is the level dropping off?
After an oil change, let car sit overnight on a level surface. The next morning, check and record the level you see on the stick. That's your "full" mark. Assuming you have added the amt. of oil stated in owners manual AND that you are using a factory filter. The idea is to get everything the way it was when the car came off the line.
Check oil level on stick say every week. Same deal. Let it sit overnight on a level surface. Record level and compare to level the morning after your last change. Any difference?
What's the level look like after 3000 miles?
Some will argue that you should check oil level when hot and after sitting for just a few mins. Some mfgs. started using this approach in the mid-90s. Some will say check level hot, but after sitting for a couple of hours.
For the purposes of determining oil consumption, you can use whatever technique you like as long as your consistent in your approach.
If you are using oil, the next step would be to determine if your motor is "consuming" it or "leaking" it.
And last, but not least, understand that some engines simply use a little more oil than others.
Old 10-04-2007, 11:42 AM   #5 (permalink)
View toyomoho's Photo Gallery
With this many miles on the engine burning one quart per 3K miles is OK.
Place cardboard under the engine when the car is sitting overnight and check for oil leaks. Check for small leaks around the valve covers, bottom of front timing belt cover and distributor. Look for white exhaust smoke at cold engine startup, a sign the valve stem seals may be wearing out.
Old 10-04-2007, 12:18 PM   #6 (permalink)
View mrbill5's Photo Gallery
98 XL, 93,000 miles, burns less than 0.5 qt over 4,000 miles.
Don't think I ever topped the oil between oil changes in 9 years.
Mr Bill5
mrbill5 is offline   Reply With Quote
Old 10-05-2007, 03:09 PM   #7 (permalink)
View edbro9's Photo Gallery
I only have 80K but I don't burn a single drop. I have usually used Mobil Synthetic and an oversized oil filter (FRAM XG 3600). I also did a preventive application of AutoRX.
edbro9 is offline   Reply With Quote
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
oil consumption - install TRD supercharger? OPINIONS PLEASE!! 97trdcamry 3rd & 4th Generation (1992–1996 & 1997–2001) 11 08-03-2008 09:08 PM
Oil Change Question With 5w30 Kendall MIAMI-DADE-1 5th & 6th Generation (2002-2006 & 2007-2011) 19 03-04-2007 03:49 PM
funny oil change docktortal33 2nd Generation (2005+) 7 08-08-2006 03:17 PM
Oil light problem and CV joints question Akuma Tercel, Paseo, Starlet, and Sera Forum 4 03-13-2006 10:59 AM
