95 avy thrid light problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-14-2007, 01:26 PM   #1 (permalink)
View Heavy_D's Photo Gallery
ok, this happin a long time ago, but it bothering me know cause of the gauge light, but i installed my radio, amp and 2 12s and now the third brake light wont light up, b4 it was working now it dont, any one has any ideas?
Heavy_D is offline   Reply With Quote
Old 10-30-2007, 08:02 PM   #2 (permalink)
any has this problem? my thid light wont light up, and has anyone ever installed a new valve cover gasket? mines old now and starting leak oil, and does anyone know the codes for the ABS light? i have the light on, and i need to know what side of the tire it is, need the help peoples.
Old 11-02-2007, 01:25 AM   #3 (permalink)
View toyomoho's Photo Gallery
Download the service info for the Gen 3 Camry, the two cars are almost the same. If this car has ODB II try the Gen 4 Camry. The SRS codes are pretty much standard between Toyota models.
http://www.camrymanuals.com/
Is the brake light failure indicator on? Have you checked to see if power is getting to the 3rd light socket, bulb failure?
For the valve covers do a TN Camry history search. The Camry V6 option is the same engine as Avalon. Also look in the Camry service manual under the 1MZ-FE engine.
Real HID's not necessarily "better" fredster34 5th & 6th Generation (2002-2006 & 2007-2011) 26 12-11-2006 06:06 PM
[HELP] Problem on installing fog light bowen Camry & Solara Lounge 9 05-31-2005 07:32 PM
95 Avalon Check Engine Light and Flashing OD Light teke175 1st Generation (1995-1999) 0 04-27-2005 10:17 AM
95 Corolla charging problem jeb Archived Corolla threads 2 10-04-2004 12:29 PM
96 Camry: sunroof and reading light problem Newbie Hardcore Tech and Competition 1 10-09-2002 10:12 AM
