avalon brake bleeding - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2007, 12:28 PM   #1 (permalink)
View lizsampson's Photo Gallery
Howdy all, I drive a hand-me-down 1995 avalon with 200k on it.
it's been pretty great, did the starter last week, and this past weekend i put in a used right rear caliper. now i have NO pedal! I've bled and bled, to no avail. Seems like the left rear and right front bled ok, but the other 2 didn't seem to bleed. fluid came out, but the pedal didn't depress when I opened the bleeders.
What's up with that?
Help me anyone, please!!!???
driving it like this is scaring me and everyone else!
thanks, Liz
lizsampson is offline   Reply With Quote
Old 10-30-2007, 12:51 PM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135623
View Hajoca's Photo Gallery
You must get someone to depress and hold pedal while you bleed , or else you can try those 1 man units but you get less feedback and will be slower.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 10-30-2007, 12:54 PM   #3 (permalink)
I guess I should have wrote in that I had a pal in the driver's seat the whole time, putting up with my yelling commands and then some swearing.
I'm wondering if there is any procedure needed in addressing the ABS?
I had inadvertantly allowed the resevoir to empty. Now I think there's air everywhere.
Old 10-31-2007, 08:03 PM   #4 (permalink)
daveart's Avatar
View daveart's Photo Gallery
Canada
you say it was a used caliper,mabey they are seized?whenn bleeding do the pistons come out?
daveart is offline   Reply With Quote
Old 11-02-2007, 11:34 AM   #5 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
"I had inadvertantly allowed the resevoir to empty. Now I think there's air everywhere."
Possible causes:
1. Fluid leaks for brake system
2. Air in brake system
3. Piston seals (Worn or damaged)
4. Rear brake shoe clearance (Out of adjustment)
5. Master cylinder (Faulty)
6. Booster push rod (Out of adjustment)
If the master cylinder has been disassembled or if the reservoir
becomes empty, bleed the air from the master cylinder
(a) Disconnect the 2 brake lines from the master cylinder.
(b) Slowly depress the brake pedal and hold it.
(c) Block off the outlet plugs with your fingers, and release
the brake pedal.
(d) Repeat (b) and (c) 3 or 4 times.
NOTICE:
Bleed air of the rear brake first. If front brake is bled first,
rear brake air cannot be bled.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Brake Job Totural Pimpinda93camry 3rd & 4th Generation (1992–1996 & 1997–2001) 10 10-11-2010 12:52 PM
Avalon rear disc brake fit on a gen4 cam? RED171 3rd & 4th Generation (1992–1996 & 1997–2001) 2 11-30-2005 08:47 AM
New 2005 Toyota Avalon Unveiled! Ratko Toyota News 64 05-04-2005 12:14 AM
Rotora Big Brake Kits for AVALON, SOLARA, CAMRY, RAV 4, LEXUS ES300 cam2Xrunner 2nd Generation (2000-2004) 38 02-23-2005 04:39 PM
Ford brake conspiracy EKam Hardcore Tech and Competition 19 04-02-2004 07:17 PM
