98 Avalon Radiator Fan - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2007, 11:47 AM   #1 (permalink)
View JoelP's Photo Gallery
USA 98 Avalon Radiator Fan
My radiator fan runs constantly when key is on. Has done this in the past, but I replaced the AC Head Amplifier (computer) for $500 or so , but now it's on again. Maybe a temp sensor now? JoelP
JoelP is offline   Reply With Quote
Old 11-10-2007, 01:56 PM   #2 (permalink)
View toyomoho's Photo Gallery
The coolant fans are controlled by a series of relays. The radiator fan is tied to a temp switch installed in the radiator. The AC fan is linked to the AC compressor such that both are on or off at the same time. The radiator fan will remain on if there is an open wire in the system as a fail-safe option.
Suggest you download the wiring diagram for the Generation 4 Camry (V6 option); the two cars are almost the same. Then check for issues with wiring and control relays.
http://www.camrymanuals.com/
History of the Toyota Avalon Ratko 1st Generation (1995-1999) 6 04-01-2012 09:05 AM
98 Avalon Starter Problem alien4ever 1st Generation (1995-1999) 10 10-07-2010 11:10 AM
HU install in a 98 avalon xl supra06 1st Generation (1995-1999) 14 11-21-2006 11:00 AM
Avalon 98 wheels&tires upgrade kidreturn 1st Generation (1995-1999) 2 06-09-2006 01:24 AM
body kits for avalon 98 xls ? xchopperx22x 1st Generation (1995-1999) 1 05-29-2005 09:42 AM
