Brake fluid leaking at caliper brake hose - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2007, 06:32 AM   #1 (permalink)
View quickhands's Photo Gallery
hi,
does any one know if there are one or two copper washer at the brake hose connection and the brake caliper? i recently replaced the caliper and replaced one copper washer wasn't sure if it had a second one. it wasn't leaking for a while then suddenly it starts to leak. i tighten the bolt to 33 lb-ft torque.
quickhands is offline   Reply With Quote
Old 11-13-2007, 09:57 AM   #2 (permalink)
Avalon Enthusiast
Gameroom cash: $102015
View inov8's Photo Gallery
You didn't specify model year (or I missed it). I can only answer for '05.
The assembly consists of:
Bolt - washer - flexible line fitting - washer - caliper.
Sometimes a "U" shaped double washer is uised in place of 2 single ones. The "U" fits over the end of the flexible brake line, so you end up with a washer on each side.
The washers are typically crushable copper and only intended for one-time use. Re-used washers sometimes leak.
inov8 is offline   Reply With Quote
9th gen Transmission fluid exchange, observations and questions. cdherman 9th Generation (2003-2008) 36 08-24-2009 05:37 PM
HELP!!! Weird/Strange Sound from Transmission after ATF Change junkyudog 5th & 6th Generation (2002-2006 & 2007-2011) 31 10-12-2007 09:09 PM
Changing Brake Fluid xxsienmixx 1st Generation (2001–2007) 7 08-03-2007 08:22 AM
SW20 brakes for the do-it-yourselfer ... KAOS MR2 Forum 11 09-18-2004 01:21 AM
my power steering fluid is leaking mkII Camry & Solara Lounge 1 01-09-2003 08:23 PM
