Car throwing codes. Need help. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2007, 05:10 PM   #1 (permalink)
View lv6l's Photo Gallery
Hi, I have a 97 Toyota Avalon XLS. My car is throwing three codes. They are: P0135, P1705, P0135. There are two P0135 because the O2 sensor is defected in two different reason. It says its Bank 1, Sensor 1. The P1705 has to do something with the transmission. I forgot what it said exactly. My concern is I need to smog my car. I live in California so does O2 sensors matters? Also if someone can help me fix my P1705 codes too that would be great. Thanks.
lv6l is offline   Reply With Quote
Old 11-25-2007, 06:32 PM   #2 (permalink)
View toyomoho's Photo Gallery
P1705 Direct Clutch Speed Sensor, see link below for details on this code
http://autorepair.about.com/library/faqs/bl248h.htm
There is only one Bank 1, Sensor 1. Location is on exhaust manifold nearest firewall.
Old 11-25-2007, 08:31 PM   #3 (permalink)
Oh thank you. I'm planning to buy a replacement O2 sensor from autozone. I live in california, would autozone's O2 sensor be able to pass me for smog? Also i'm about to read up on the link you provided but I just want to add that the "trac off" light is on in my car's dashboard. It will not turn off, it stays lit, even when I push the "trac off" button. What could cuase this?
Old 11-25-2007, 11:28 PM   #4 (permalink)
View sheepwundr's Photo Gallery
dont buy the autozone o2 , toyotas dont like autozone parts. if you are installing it yourself just buy the toyota one this way you only buy it once. the reason your trac light is on is because the check engine light is on. it is a default/ limp home mode.
sheepwundr is offline   Reply With Quote
Old 11-26-2007, 03:31 AM   #5 (permalink)
Oh, how much does the toyota o2 sensor cost? How many o2 sensors does the avalon have? If multiples, what do I ask for when i'm at the dearler. Sorry for all the questions, I have work on a lot of hondas and nissans before, toyota are a bit new to me.
edit: sorry. forgot about an earlier post above mention already how many o2 sensors the avalon has.
Old 11-28-2007, 03:10 PM   #6 (permalink)
Hey guys, there was a link in a previous post above that shows you how to test if a Direct Clutch Speed Sensor. My question is im throwing a code P1705. Would replacing the Direct Clutch Speed Sensor fix my code? Thanks.
edit: later today i went to toyota dealership to do a price check on the two parts. they found the o2 sensor(part # 89467-41021) for $208.92. it took them a while and the best they can find for the direct clutch speed sensor is a "speed sensor"(part # 89413-08020) for $108.43. i would like to know am i looking for the right speed sensor. is there really a thing called direct clutch speed sensor or there is another name for it. im planning to buy the o2 sensor but i'm still stump on how to fix my P1705 code(direct clutch speed sensor).
Old 11-29-2007, 03:39 PM   #7 (permalink)
Can someone please help me locate my Direct clutch speed sensor in my 1997 Toyota Avalon XLS pleae. Thank you.
Old 12-01-2007, 03:50 AM   #8 (permalink)
bump'
Old 12-02-2007, 12:29 AM   #9 (permalink)
nobody? is there even a direct clutch speed sensor on avalons? i check on mine and thinking it might just be a speed sensor. but the code reader says something is wrong with the direct clutch speed sensor. toyota guru, come read please help me find my direct clutch speed sensor....if there is one on my car. thanks.
Old 12-02-2007, 05:15 AM   #10 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Dude, look at the link Toyomoho put up in the second post. It's got a diagram of where it is as well as test procedures for checking it.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 12-03-2007, 08:05 PM   #11 (permalink)
i wouldnt be asking again if i have found it. i have check the link and under the hood of my car cannot find it. i went to toyota dealership and they dont have any "direct clutch speed sensor" part for an avalon. they only have speed sensor. thats why i'm concern about this issue now. does avalon have direct clutch speed sensors? or do they have a different name?? that link is for a 96ish camry. i would think it be very similar but something is not the same here...
also from the link. when trying to find the direct clutch speed sensor would i be under the car looking up or on top of the car looking down into the engine bay?? sorry for any inconvience but i cannot tell what the picture is saying.
Old 12-03-2007, 08:34 PM   #12 (permalink)
Qslim's Avatar
Everything in that link is the same for an Avalon. The clutch speed sensor is on top of the transmission pointing down, fastened by one 10mm bolt. The parts dept probably lists it as a transmission speed sensor. Try part # 8941308020.
-- Get him, boy....
Old 12-03-2007, 11:21 PM   #13 (permalink)
i see. thank you for the information. do you know if the transmission speed sensor is the same as the direct clutch speed sensor?
Old 12-04-2007, 01:19 AM   #14 (permalink)
Look at the trans and see if has two speed sensors. One should be mounted on top of the differential housing where the axles come out (vehicle speed sensor). The other might be on top of the trans toward the driver side and inline with where the trans main shaft (see photo in link).
Old 12-04-2007, 03:52 AM   #15 (permalink)
thanks for the info. i went outside and took some pictures of the two things i can find on the transmission that i would guess best to be my two speed sensors. i outlined in red at the sensor i saw.
which sensor is this one? to the right of the picture is the rack and pinion and firewall. to the left of the picture is the front of the car.
and which is this one? to the left of the picture is the starter and front of car. to the right of the picture is the firewall.
also i have been facing issues relating to transmission issue and trac off light is staying light up i found this under the dash near the handbrake pedal. after removing the driver's side kick shield and exposing all the wires i see this one wire that seem to be hook onto...well let the picture tell the store....it didnt seem oem to me. so maybe you guys can help me figure out what this is all about.
this is what i looks like. in red i outlined where it was ground, and then plugged into a wire.
closer look of where the unknown wire is plugged into.
the unknown wire travels north upto the gauge area where i cannot see specifically where it goes. it disappear somewhere up there.
i hope all these picture help. thanks in advance for any inputs on trying to help me out.
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
FS: 1986 Corolla GTS VanishingVision Vehicles 4 06-24-2007 04:52 PM
FS, 02 Benz Coupe Showcar joesc230 Vehicles 2 01-15-2007 08:32 AM
New Car Questions TX WJ Camry & Solara Lounge 1 04-29-2006 07:54 AM
For Sale: 1991 Toyota MR2 non-turbo automatic (many pics) LarryDallas Vehicles 2 07-07-2005 03:15 AM
