Headlight washers not working! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2007, 09:13 AM   #1 (permalink)
96Avalon_Matt's Avatar
View 96Avalon_Matt's Photo Gallery
Hello,
Since I bought my 96 Avalon XLS, the headlight washers have not worked. What could be the problem? I checked the fuses. Do the headlight washers have a separate pump that could be busted, or could it be the tubes are blocked? My windsheild wipers work flawlessly.
96Avalon_Matt is offline   Reply With Quote
Old 11-28-2007, 11:41 PM   #2 (permalink)
Posting via iPhone/iPad
CupCate18's Avatar
Gameroom cash: $373364
View CupCate18's Photo Gallery
easiest thing to do would prob check to see if they are clogged first. Beyond that, count me as clueless.
RWD 5-speed Zoom-Zooms
My car has less body roll than I do.
When you want sports car handling, you buy a sports car.
CupCate18 is offline   Reply With Quote
Old 11-29-2007, 01:04 AM   #3 (permalink)
The Connoisseur
CharmCityES's Avatar
well check to see if they washers are clogged as catherine stated....and next check the tubes and see if they are clogged or disconnected....they run off the same resivor tank and pump, so if the wisndshield washer nozzles work then the pump is good...check to make sure all the hardware is functioning properly before you delve into electrical issues, which i seriously doubt are the source of the issue
The "Executive Sedan"
H4 Angel Headlight conversion kit 87AW11 Feedback: Buyers, Sellers, and Vendors 0 02-15-2007 03:21 PM
RH Low Beam of Headlight not Working Shinto 3rd & 4th Generation (1992–1996 & 1997–2001) 4 11-14-2006 02:56 AM
HELP!! Major Gen2 Headlight Problem jkgstl 1st & 2nd Generation (1983–1986 & 1987-1991) 2 04-23-2006 10:17 AM
NOT another headlight alignment topic... _VVTi_ Camry & Solara Lounge 6 08-26-2004 03:12 AM
