Heater Core Removal Issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2007, 06:43 PM   #1 (permalink)
Mex
View Mex's Photo Gallery
I went out and got a Haynes manual to fix the heater core in my 97 Avalon and the directions shown made it look so simple:
The problem is, the metal chassis bar is in a different place on MY car:
it comes right in front of the connection points, and one of the screws I need to get to is impossible to reach with that bar there. and it seems to be welded in place! I just can't figure this out. every other model year, the directions look so simple. I've looked at the directions for the 96 & 97 camry, the 97 lexis ES300, none of them have that chassis bar there
if anyone has a repair manual for the specific 95-97 Avalon model year, or knows something I don't, please help!
Mex is offline   Reply With Quote
Old 11-27-2007, 07:07 PM   #2 (permalink)
View toyomoho's Photo Gallery
Can you drill out, grind or break off the fastener with a chisel? Once removed drill another hole in both bracket and mounting structure and install another bolt.
Old 11-27-2007, 07:13 PM   #3 (permalink)
Mex
here's a picture so you can better see what I mean:
i drilled that sorry looking hole to reach the screw, but even with the clamp removed, I can't slide it out with that bar there :/
Old 11-27-2007, 10:06 PM   #4 (permalink)
View Medi.'s Photo Gallery
you can't get to it from the other side of bar?
Medi. is offline   Reply With Quote
Heater hose connection - removal - weird split pin design... poiter_mcd Archived Corolla threads 1 07-11-2007 12:31 AM
Smelly heater core? 25psi 1st & 2nd Generation (1983–1986 & 1987-1991) 2 01-13-2007 04:15 PM
heater issue bowlofturtle Camry & Solara Lounge 22 04-28-2005 03:57 PM
Heater core kc_jon Supra Forum 1 11-27-2004 11:15 PM
heater core help please!!!!!!!!!!! jasonhow General Discussion 2 10-20-2004 09:41 PM
