Valve cover gasket replacement?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-05-2007, 09:51 PM   #1 (permalink)
View 96AvalonOwner's Photo Gallery
USA Valve cover gasket replacement??
Folks,
Any experience with valve cover gasket replacement? Also I want to know what material to use for the mating surfaces to "seal" it properly and where should it be applied. Haynes manual says to apply it only at 3 places.
Please share your experiences. I need to replace it both on the left and right side.
96AvalonOwner is offline   Reply With Quote
Old 12-06-2007, 09:46 AM   #2 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Originally Posted by 96AvalonOwner View Post
Folks,
It's a pain in the ass, but pretty straightforward. Just go step by step and organize all the bolts so you have them all when you're done. As far as the sealant, the haynes manual has it right. We use a stuff from Toyota called FIPG (form in place gasket), but you can also just pick up a tube of black RTV (room temperature vulcanizing) sealant from any parts store.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 12-06-2007, 03:00 PM   #3 (permalink)
View toyomoho's Photo Gallery
Most auto stores sell a FIPG product. Would throughly clean the gasket contact area on the head then apply a thin coat to the sealing area.
Be sure to torque down the spark plug tube nuts in stages to pull the gasket down firmly. Once at the specified torque, wait a few minutes and retorque.
Old 12-06-2007, 07:51 PM   #4 (permalink)
USA Valve cover gasket - Anything else should be replaced?
As a maintenance issue, should anything else be replaced (other gaskets) when I have the things out to replace the valve cover gaskets?
Thanks.
Old 12-06-2007, 08:17 PM   #5 (permalink)
Qslim's Avatar
Well, changing the spark plugs would certainly be easier with the intake off.
-- Get him, boy....
Valve Cover Gasket Tecnic 4Runner Lounge 1 11-21-2007 06:21 PM
Valve cover gasket, and an oil leak wahed3001 3rd & 4th Generation (1992–1996 & 1997–2001) 17 11-15-2007 06:18 PM
94 Camry I4 Valve Cover Gasket bhavinjo 3rd & 4th Generation (1992–1996 & 1997–2001) 7 10-27-2006 04:00 PM
gen 2 v6 valve cover gasket install smkdwnn 1st & 2nd Generation (1983–1986 & 1987-1991) 3 08-22-2006 01:14 PM
1989 Camry Valve Cover Gasket Sofortiger Tod 3rd & 4th Generation (1992–1996 & 1997–2001) 4 06-11-2006 11:22 AM
