Rear window switch replacement. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2007, 08:17 PM   #1 (permalink)
View 96AvalonOwner's Photo Gallery
USA Rear window switch replacement.
Folks,
I have a 96 Avalon XLS. The driver side rear window does not roll down. However, when there is heavy rain and I press down the window switch (in the driver side door panel), it works sometimes and the window rolls down. So I know that the motor is fine. How do I replace the switch (I do not know how to get the panel off which has all the window switches). Is there a special tool to get the panel off? Also is replacing the switch straightforward and if so what should I order?
TIA.
96AvalonOwner is offline   Reply With Quote
Old 12-06-2007, 09:27 PM   #2 (permalink)
Napa Burgundy '98 Avy
View cexsiman's Photo Gallery
no special tools, just a flathead screwdriver. stick it down from the top(pointy part) around 1 1/4 inches and pry up in the middle. and thats it. any questions, just ask
cexsiman is offline   Reply With Quote
Master window switch re-wiring... xtremeskier97 3rd & 4th Generation (1992–1996 & 1997–2001) 4 10-08-2007 01:20 PM
rear leaf replacement and lift Shawster 2nd Generation (2005+) 4 09-07-2007 11:15 PM
2007 Camry Rear Window Visibility SLM 5th & 6th Generation (2002-2006 & 2007-2011) 16 05-27-2006 08:59 AM
'05 XLE: rear window FM antenna connection bpsmicro 5th & 6th Generation (2002-2006 & 2007-2011) 3 12-02-2005 03:15 PM
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 10:36 PM
