PUZZLE - Rear window switch replacement. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2007, 08:19 PM   #1 (permalink)
View 96AvalonOwner's Photo Gallery
USA PUZZLE - Rear window switch replacement.
Folks,
I have a 96 Avalon XLS. The driver side rear window does not roll down. However, when there is heavy rain and I press down the window switch (in the driver side door panel), it works sometimes and the window rolls down. So I know that the motor is fine. How do I replace the switch (I do not know how to get the panel off which has all the window switches). Is there a special tool to get the panel off? Also is replacing the switch straightforward and if so what should I order?
Btw, the window DOES NOT roll down from the rear door control either. So I am assuming that both the switches are non-functioning, though that would be rare. But then the window rolls down from the driver side switch during rain. Could anything else be wrong
TIA.
96AvalonOwner is offline   Reply With Quote
Old 12-07-2007, 04:53 PM   #2 (permalink)
Napa Burgundy '98 Avy
View cexsiman's Photo Gallery
hey, i thought i replied to your post, but i dont see it showing.
all you need is a flat head screwdriver, slide it in from the top (pointy part of the switch) and pry up in the middle of the panel, there is a small metal clip holding it down in the front and tabs that slide into the arm rest in the back. when i did it, i didnt think it was going to give or i was going to break something, but its the right way to do it (and only) . any Q's just PM me.
cexsiman is offline   Reply With Quote
Old 12-07-2007, 05:08 PM   #3 (permalink)
Thanks. Got it. Btw, what do you think of the problem I am having. Do you think that the harness just needs to be cleaned (master control switch for the rear window and the rear window switch for the glass) or both the front and back switches have gone bad?
05 tundra, sliding rear window? farrington300 1st Generation (2000–2006) 4 12-14-2007 06:20 PM
Master window switch re-wiring... xtremeskier97 3rd & 4th Generation (1992–1996 & 1997–2001) 4 10-08-2007 01:20 PM
rear leaf replacement and lift Shawster 2nd Generation (2005+) 4 09-07-2007 11:15 PM
2007 Camry Rear Window Visibility SLM 5th & 6th Generation (2002-2006 & 2007-2011) 16 05-27-2006 08:59 AM
Replacement Rear Window (with topper) peers 2nd Generation (2005+) 2 08-26-2005 11:45 PM
