Fuel filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2007, 05:44 PM   #1 (permalink)
View rshep's Photo Gallery
Fuel filter
Hi, I've got a '98- #1- How do you get the fuel filter off the fuel line?
#2- Does the fuel system depressurize after a couple of days and if not, How do you do it?
Thanks
rshep is offline   Reply With Quote
Old 12-29-2007, 06:22 PM   #2 (permalink)
View toyomoho's Photo Gallery
To depressurize place a rag around the joint you are breaking loose to deflect and absorb any gasoline that will spray out. It is best to use a flare tub wrench for the steel fuel line nut, this prevents rounding the nut corners. Also use a wrench on the filter nut to keep the filter stationary.
Old 12-30-2007, 09:07 AM   #3 (permalink)
Its not a nut. Its some weird clip with a u-shaped cap on top.
Thanks anyway
Old 01-02-2008, 10:40 PM   #4 (permalink)
Rubber hose on top, tube fitting nut on bottom.
K&N: Why take filtercharger over drop-in filter? dELuX-4x4 2nd Generation (2005+) 88 10-02-2007 01:13 AM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
For Sale Brand New Camry Hybird for just $19000 cars01 Camry Hybrid 1 04-07-2007 06:00 PM
Fuel pump and Fuel filter secaII4884 89-95 Toyota Pickup/Hilux 2 03-06-2007 11:10 AM
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
