99 Avalon spark plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2007, 02:06 PM   #1 (permalink)
View inspmm's Photo Gallery
I'm coming up on 60k miles and the Toyota maintenance schedule calls for spark plug replacement . I've heard that the original stock plugs are good for many miles past 60k. What's your experience?
inspmm is offline   Reply With Quote
Old 12-31-2007, 04:56 PM   #2 (permalink)
View fj40supraman's Photo Gallery
They are dual eletrode platinum Densos. Price the OEMs and you will see that they are quite expensive. I'd not worry about them until 100k unless you are having problems (rough idle, bad fuel economomy, etc...)
Current- '97 Avalon w/ 100k
'99 Avalon w/ 200k, sold to friend (1MZ-FE)
'86 4-Runner- wrecked and sold (22R-E)
'85 Corolla- engine lost compression=junkyard (4AC)
(3S-GTE MR2 or 2JZ-GTE Supra as soon as eng. degree pays off)
fj40supraman is offline   Reply With Quote
Old 12-31-2007, 07:54 PM   #3 (permalink)
View toyomoho's Photo Gallery
Spark plug replacement is most likely based on maintaining emissions standards rather actual plug life, platinum plugs should last at least 100K.
Old 12-31-2007, 09:12 PM   #4 (permalink)
Thank's for the info..... car runs fine no problems. Think I'll leave the plugs alone.
Old 12-31-2007, 10:49 PM   #5 (permalink)
2000-Avalon's Avatar
View 2000-Avalon's Photo Gallery
I bought my 97 avalon with 95k miles..... replaced the original plugs @ 96k miles and they were still perfect. I just got some toyota ones for $6 a piece with my discount so it was'nt harsh at all on the wallet. Good luck.
2000-Avalon is offline   Reply With Quote
Old 01-01-2008, 02:46 PM   #6 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135623
View Hajoca's Photo Gallery
The plugs are about US$10 each, or here 12.50 CDN. for the rear bank, well worth the money because they are quite difficult to change out.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 02-26-2008, 08:06 PM   #7 (permalink)
View 97avy's Photo Gallery
I'm planning on replacing the plugs on my 97 Avalon with 160k, I bought the car with 140k and owner did'nt have receipts. The idle is a slight bit rough, but still heavily impressed with the car.
anyone have a part number for the plugs? Are they Denso? Can they be bought outside (autozone, kragen, etc.)
anyone have instructions on how to change them out? Do I have to remove the rear upper intake manifold?
Thanks in advance everyone,
97avy is offline   Reply With Quote
Old 02-27-2008, 09:50 AM   #8 (permalink)
Napa Burgundy '98 Avy
View cexsiman's Photo Gallery
part numbers should be in the manual if you have it, and i can tell you that the front bank is an easy change out, but the rear bank is a tight fit. you might even want to try getting the car up in the air and working on it from underneath if you can. you dont NEEED to take it off, but get someone with small arms and thick sleeves to help you out.
cexsiman is offline   Reply With Quote
Old 03-09-2008, 08:31 AM   #9 (permalink)
View TMack409's Photo Gallery
The plugs are cheaper at the dealer than most anywhere else.....about $10 each. FWIW, the parts counter guy at my local dealership said many lift the intake manifold off to get at the rear plugs. Rubbish! They are indeed a struggle, but I've found that if the engine is warm, the plug boots will come off a lot easier. Must have powerful grip! (Perhaps they are harder to reach on other models - but mine's a 1996 and I've never had a problem.) I replace my plugs every 60K per the manual - but I do think that's conservative. I may push mine a bit longer on the next go round.......LOL at 180K miles, I don't know how many more times I'll be dealing with it anyways ;-)
Btw, your rough idle is most likely due to dirty butterfly valve in throttle body.
TMack409 is offline   Reply With Quote
Old 03-09-2008, 12:50 PM   #10 (permalink)
TN User
golfgod's Avatar
View golfgod's Photo Gallery
Changed my plugs at 120K while replacing valve cover gaskets after I bought the car. It had Denso in it, was running fine and looked like original, but previous owner didnt log maintenance so I cant be sure.
Just for kicks I went out to see if I could get at the rear. The trick was using my cheap 3/8" wobble extensions with spark plug socket. The stack up was...spark plug socket, then 3" extension, 2", 1" and then a stub swivel handle craftsman ratchet. Tip...had to drop some of the pieces in one at a time because the entire stack up wont slide in tube all together.
I agree with TMack409. Try to clean up intake to help rough idle. New air filter and the Seafoam treatment in PCV valve hose would do wonders.
Its only a transport to the golf course....
2004 Lexus ES 330
2004 Jeep Liberty Limited
2005 Avalanche Z71 Loaded
golfgod is offline   Reply With Quote
Old 03-27-2008, 11:26 AM   #11 (permalink)
View avalonian's Photo Gallery
hrm Question I have 125k on mine. my start up is a bit rough. takes 2 seconds to turn over. In need of new spark plugs? My idle is fine and steady.
avalonian is offline   Reply With Quote
Old 03-27-2008, 12:25 PM   #12 (permalink)
Wink
I'm probably the wrong person to ask, since I change mine (1996 Avalon) by the book at 60K. But I would say you are more than due...... Rough starts are cured by premium fuel. But I can't afford the luxury of premium petrol during these times.
Old 03-27-2008, 02:42 PM   #13 (permalink)
Darkside Cut Me!!!
Have you cleaned out IAC, throttle body, and replaced fuel and air filters?
2004 RX330 Sport
2003 Cam I4 XLE
Old 04-01-2008, 10:33 PM   #14 (permalink)
True Story
When I bought my first Avy It had 150K miles, had it in to the dealer to get something and I asked the service manager when should I have the wires and plugs changed. He asked how does it run. I said no problems and he replied that they don't change them based on interval anymore as they are platinum plugs. So I let them go and it's still running on them same plugs (someone else has it now) with over 230K. Still runs fine.
I recently put NGK Iridiums in my Avy and they seem to be the same as before. They have a slightly smaller electrode (more spark), but I can't tell the difference. They are suppose to last a long time. I also did the wires while I was messing with it. Back ones are a pain, but a swivel ratchet as listed above helps. Used one long extension and put antiseize on them, considering they last 100K. Hopefully I can put in another set at 300K!
Old 04-02-2008, 07:27 AM   #15 (permalink)
When the gaps in the plugs get really wide from wear - this puts a strain on the rest of the ignition system - mainly the coils, which can break down from the stress. Also, as the ignition leads wear out, they require more energy from the coil to fire the plug - so don't neglect the wires either. Plugs are cheaper to replace, than coils. Also, since our engines have only three coils, these coils work harder than a 'coil over' at each plug. That said, each coil is firing two spark plugs at the same time (one of which is of course, a waste spark but nonetheless coil energy is required). So, as I said, super wide gaps make for excessive loads on the coils.
Whilst 60K may indeed be conservative replacement interval for the OEM plug, I can't recommend placing them on the ignore list forever.............
Spark Plugs - How hard can it be? 95t100xcb T-100 7 07-28-2007 07:53 PM
How long do platinum spark plugs last? NewRacer Camry & Solara Lounge 8 05-24-2006 06:52 PM
190,000 km - 1st spark plugs change ToyotaToday Camry & Solara Lounge 8 04-22-2006 11:56 PM
Spark Plugs d0rkiishchris Camry & Solara Lounge 6 08-11-2005 11:09 PM
Anyone using Nology Silverstone Spark Plugs TRD_Rob Camry & Solara Lounge 1 03-18-2004 12:28 PM
