Oil filter change leaks oil onto exhaust pipe header - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2008, 05:57 PM   #1 (permalink)
View TMack409's Photo Gallery
Any ideas on preventing the oil from leaking down all over the exhaust pipe when spinning off the old filter? I realize that synthetic oil (which I use faithfully) is part of the problem - it never seems to burn off!
Phew!
TMack409 is offline   Reply With Quote
Old 01-07-2008, 11:00 PM   #2 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Phew!
Buy a can of brake cleaner at the parts store and empty it on the front of the engine and exhaust after you put the new filter on (not when the pipe is hot, obviously). It'll cut the oil and leave everything dry as a bone.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 01-08-2008, 09:42 AM   #3 (permalink)
View aigochamaloh's Photo Gallery
Yea, Toyota didn't think that one through. They fixed it though with the later 1MZ-FE engines. The motor mount now has a drain hole, so it goes straight to the floor. If you have shot motor mounts, just use the new ones and you won't have that problem.
aigochamaloh is offline   Reply With Quote
Old 01-09-2008, 09:29 AM   #4 (permalink)
View Joon525's Photo Gallery
My Prelude had this problem.
I just got a sheet of aluminum foil and wrapped the header before the oil change. Then I just threw it away when I was done.
Joon525 is offline   Reply With Quote
Old 02-09-2008, 04:57 PM   #5 (permalink)
My mount does have the drain hole in it that you mention - but that's not the problem's total solution.....Here's what I've done to hopefully cure the pesky leak.....
I still couldn't account for oil that kept appearing after I'd clean everything off and wait a couple of days....So out of frustration, today I removed the motor mount's upper bracket and just as I pulled it loose from the engine -out flowed several tablespoons of trapped oil down the front of the engine. (If you want the step-by-step removal process, feel free to ask me how to do this in toto - but it's pretty obvious once you get going with the job....)
What's happening is the upper mounting bracket (for the big rubber thingy) is itself flush (at the very bottom) against the engine block. This creates a pocket 'tween the mount and the engine block - that's what's holding oil in there. This pocket isn't perfectly sealed as given enough time, synthetic oil will find its way down thru any small passage - even though very slowly in this case. With everything cleaned off, it usually took a couple of days for oil to leach out and down....onto the exhaust header.
Once I got everything out of the car and cleaned up...using a round rat tailed file, I created a small path in the upper motor mount bracket - centered, down a the very bottom where it fits flush against the block - for trapped oil to drain out.
I also cleaned the area behind the mount - it was positively nasty and then put it all back together. We'll see, next time I change oil if this cures the problem once and for all!!! But I have to believe that was it....
Old 02-10-2008, 01:01 PM   #6 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
Has anyone tried this oil catch and pouring spout from the FJ Cruiser?
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 02-10-2008, 06:33 PM   #7 (permalink)
I saw that on my buddy's Tacoma, 1GR-FE if I remember correctly. Made changing the oil a lot better. Unfortunately I did not have a tube to drain the oil out, so I had to put a cup under it, but it still worked.
Old 02-10-2008, 06:52 PM   #8 (permalink)
Is it a permanent fixture? Or is it slotted - to be slid in place only when removing filter?
Filter and Oil Change jcal0820 2nd Generation (2004-2010) 8 10-16-2010 05:14 PM
Oil filter relocation warning! jeffmazz 1st Generation (1995.5–2004) 12 02-19-2009 01:24 PM
Men, Women and Oil Changes... BLUEMEANIE Off Topic 15 09-26-2007 09:42 AM
turbo abew330 Supra Forum 0 02-07-2007 05:51 PM
