Originally Posted by xcaligurl
i have a 96 avalon that doesnt seem to want to start. fuel pump is not turning. i unplugged the fuel pump and put in a new fuse in the efi spot and it still blew. so i replaced the relay. then put in a new fuse and it didnt blow until i turned key on. does anybody have any idea why this is happening
My senses tell my you have a short somewhere. try to trace the wiring harness and see if a wire is chafing against a metal paart somewhere.
Also, could be that the pump itself is mechanicall hindered, causing an overloading (larger amp draw than normal).
The fuses blow because the draw is too much. Could have melted a wire someplace, as welll.
If you can locate connectors along the wiring route, disconnect there and test the voltage to that point. Should be near 12v. If you find less, say 10v, you're in the neighbprhood.
"Can't understand why people abort Volvos, either"
'03 Toyota Avalon, 40,000 '96 Toyota Avalon, 126,000 miles
'89 Volvo 740tic, 120,000 miles '86 Volvo 240DL, 220,000 miles
'95 Ford Contour, 125,000 miles '88 Ford Escort GT, SCCA ITB
