rubber burning smell - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2008, 05:23 PM   #1 (permalink)
View hotrodchevy56's Photo Gallery
I have a 99 avalon with 109,000 miles on it. I recently started getting this smell of burnt rubber. I know this is not oil because oil smells totally different.
My brake light on the dash is on. I replaced both r and f brakes less than a year ago. The fronts sure have a lot of dust on the wheels. I thought the brakes were the issue but when I get down there I can't smell anything. I also notice that the brakes were gringing for awhile but they are not doing it right now.
The Avalon shop said the 02 needs replaced and that I have a small tranny leak.
I get the smell inside the car plus outside. I can not pin point the location of the smell. Has anyone else had this problem?
hotrodchevy56 is offline   Reply With Quote
Old 01-19-2008, 12:43 AM   #2 (permalink)
View 1993CamryLEv6's Photo Gallery
Is your emergency brake on?
1993CamryLEv6 is offline   Reply With Quote
Old 01-19-2008, 02:27 PM   #3 (permalink)
No,
Old 01-19-2008, 02:29 PM   #4 (permalink)
Posting via iPhone/iPad
CupCate18's Avatar
Gameroom cash: $373364
View CupCate18's Photo Gallery
Maybe have brake fluid leak? I know when it gets low, the light comes on. But don't think it would cause a smell unless you have basically no brake fluid.
RWD 5-speed Zoom-Zooms
My car has less body roll than I do.
When you want sports car handling, you buy a sports car.
CupCate18 is offline   Reply With Quote
Old 01-21-2008, 07:04 AM   #5 (permalink)
View ChiTDI's Photo Gallery
If your brake light is on, check the fluid. Then check the sensors and the rubber covered wires for wear/breaks/shorting/etc. Handbrake cable may not be releasing like 1993 said. f&r!
ChiTDI is offline   Reply With Quote
Old 01-21-2008, 01:25 PM   #6 (permalink)
when i release the emergency brake, i have to pull the release and manually pull the brake lever up.
Old 01-21-2008, 02:16 PM   #7 (permalink)
yota.coma's Avatar
View yota.coma's Photo Gallery
too much horsepower mabye. just burnin those tires everytime you go?? sorry i had to
yota.coma is offline   Reply With Quote
Old 01-21-2008, 09:35 PM   #8 (permalink)
The smell and the light could be two separate problems. Let's get some info before you go flying through an intersection with no brakes!
Burning rubber could be fluid or belts and hoses - frozen pulley, frayed sensor wire rubbing on the rotors,...
Take a look and tell us !
2007 Yaris burning rubber smell shihtzupoodles Yaris, Vitz and Echo Forum 3 03-22-2012 04:21 PM
hard steering, burning rubber smell louie1086 3rd & 4th Generation (1992–1996 & 1997–2001) 1 11-12-2007 12:05 AM
Burning Rubber Odor Roger R. 5th & 6th Generation (2002-2006 & 2007-2011) 5 03-23-2007 04:56 PM
2007 Yaris burning rubber smell shihtzupoodles Yaris, Vitz and Echo Forum 5 03-05-2007 12:35 PM
rubber burning smell in car rjw_mpwr General Lexus Discussion 3 12-17-2004 11:39 AM
