'97 Avalon Sway Bar Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2008, 10:49 AM   #1 (permalink)
View tamraw's Photo Gallery
I know nothing about cars and am trying not to get swindled like always. I have a thick bar broken in half hanging down inside of my front driver's side tire. I had one person look so far and they said it was a sway bar and that they would have to get into the steering column to fix it and that they didn't do that. They referred me somewhere else, but the question is that when I look up sway bars on the internet, they don't look the same. The parts I see on the internet are the upper part that is coming down from somewhere up above. But, the part that is broken is the large (approx 1 inch diameter) bar that is supposed to go horizontal toward the middle of the car. This has snaped. Is this indeed a sway bar? Does anyone have any idea what it SHOULD cost to fix something like this? The car runs as smooth as ever and I don't even know how long it has been hanging there! Thanks for any advice.
tamraw is offline   Reply With Quote
Old 01-20-2008, 02:58 PM   #2 (permalink)
'07 Avalon Limited
Tom in Tacoma's Avatar
Gameroom cash: $354645
View Tom in Tacoma's Photo Gallery
What you're discribing sounds like the sway bar. It shouldn't be all that costly to replace. There's plenty of Toyotas in junkyards that could give up that part - couldn't imagine it would be in high demand.
Once it's replaced you'll see how much better the car rides. You'll be surprised!
Tom in Tacoma is offline   Reply With Quote
Old 01-20-2008, 05:03 PM   #3 (permalink)
View ranger55's Photo Gallery
I've never heard of sway bar breaking in half, but anything is possible. You can go to junkyard as mentioned and get a replacement. If you can't do the install yourself, then get a price from a reputable repair shop to install the part. The issue is that you do have to disconnect the steering column neck from the rack and pinion. After that the 2 rear H-frame bolts are removed (with a support jack holding the rear of the frame) giving just enough clearance to access the 4 bolts to remove the bar and install the new one. Its not an easy repair and you can do more damage by not being experienced. Probably at least 2 hour repair.
Good luck
ranger55 is offline   Reply With Quote
Old 01-21-2008, 09:06 AM   #4 (permalink)
Thanks
I appreciate the input! I will stop by a shop on my way into work this morning.
History of the Toyota Avalon Ratko 1st Generation (1995-1999) 6 04-01-2012 09:05 AM
Quick Whiteline Rear Sway Bar Install Question Regarding Bushings darksparkz 3rd & 4th Generation (1992–1996 & 1997–2001) 7 02-16-2008 05:02 PM
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 05:51 AM
X Runner front sway bar question.. Droppedmytaco 2nd Generation (2005+) 1 04-27-2006 12:03 AM
