[quote=tmctodd;2147037]Good Day to All,
I am unable to open the passenger side rear door on my Avalon from the inside of the car.
Todd,I just got finished replacing a cable on the driver's side front door of a 2001 Avalon so I hope this is still the same set-up on yours.. It was doing the same thing ..i.e. It would open fine from the outside handle but the inside handle was not engaged. Found that the cable to the inner door handle was broken. Ten bucks at Toyota for the cable. Make sure that they order the correct cable there are two. Stress that it is the inner door cable that is broken. They gave me the wrong cable first ttime around.
After getting the door panel off you have to feel your way to get the connecting rods disengaged from the door latch mechanism. There is a plastic tab at the end of each rod where they are attached to the cable that flip up and allow you to disconnect the rods. This took me a bit of time since on the front door at least you're working in the blind. After that it's just a matter of attching the new cable and reconnecting the rods. Let me know if there is anything more I can do for you...
I got quite a bit of help from Qslim who is also on this forum. Here is a copy of the front door system. Sorry I don't have the rear door but I'm sure it is basically the same......Butch
This is out of your manual, the latch assembly is at about 8:30.
Did you disconnect the two control rods on the back side? They're tough to see, you almost have to do it by feel.
